Fullbuffer for local image operations
OP #5240986
• ▲ useful
▼ not useful
Hello,
I want to design a "fullbuffer" to better handle image operators like
sobel on a fpga. It is designed to be generic, so that the mask height,
mask width (used to define the pixels the local operator is executed
on), the pixel data width and the width of the image (in this case
mask_width + linebuffer_length = image width) can be tuned. I have
attached an image to better demonstrate the functionality (The example
uses a 3x3 mask and therefore 2 linebuffers to cache needed pixels). If
necessary I can describe the functionality in more detail. Unfortunately
there is a bus conflict while writing the "mask_ffs" signal (a 2d array
that is forming the flipflops of the mask) in the for generate loop,
which is instantiating the linebuffers (specificly in the line that
says: "dout => mask_ffs(i+1, 0)" ). I could not detect any mistakes in
my indices, or my coding.
I would be very thankful if you could help me figure out the mistake.
library ieee;
use ieee.std_logic_1164.all;
--use ieee.numeric_std.all;
use work.utils.all;
-- defines constants for generics and type "generic_port_matrix" a 2d array(mask_height-1 downto 0, mask_width-1 downto 0) of std_logic_vector(data_width-1 downto 0) (first the y coord and then the x coord, with 0, 0 in the bottom right corner if you are using the attached image as reference)
entity fullbuffer is
        generic (
                linebuffer_length : integer := linebuffer_length;
                data_width : integer := data_width;
                mask_width : integer := mask_width;
                mask_height : integer := mask_height
        port (
                clk : in std_logic;
                we : in std_logic;
                din : in std_logic_vector(data_width-1 downto 0);
                dout : out generic_port_matrix
end fullbuffer;
architecture fullbuffer_arch of fullbuffer is
        signal mask_ffs : generic_port_matrix;
        type generic_vector is array(mask_height-1 downto 0) of std_logic_vector(data_width-1 downto 0);
        signal mask_out : generic_vector;
30
31
begin
32
33
        -- output mask
34
        dout <= mask_ffs;
35
36
        -- instantiate the linebuffers
37
        line_generate:
38
        for i in 0 to mask_height-2 generate
39
40
                linebuffer: entity work.linebuffer
41
                generic map (
42
                        length => linebuffer_length,
43
                        data_width => data_width
44
45
                port map (
46
                        clk => clk,              -- in
47
                        we => we,                -- in
48
                        din => mask_out(i),      -- in
49
                        dout => mask_ffs(i+1, 0) -- out
50
51
52
        end generate line_generate;
53
54
55
        process (clk)
56
        begin
57
                if (clk'event and clk = '1') then
58
                        if (we = '1') then
59
60
                                -- shift registers of mask
61
                                for i in 0 to mask_height-1 loop
62
                                        for j in 0 to mask_width-2 loop
63
                                                mask_ffs(i, j+1) <= mask_ffs(i, j);
64
                                        end loop;
65
66
                                        mask_out(i) <= mask_ffs(i, mask_width-1);
67
                                end loop;
68
69
                                -- input new pixel from sensor
70
                                mask_ffs(0, 0) <= din;
71
                        end if;
72
                end if;
73
        end process;
74
75
end fullbuffer_arch;
  • [vhdl]VHDL-Code[/vhdl]
