How to create a pos-edge Write pulse into a neg-edge pulse?
OP (Company: none) #5229034
• ▲ useful
▼ not useful
I have a data source signal that transitions high on the positive edge
of its clock when it has data ready to be written.
I also have ram memory that expects it's write request signal to
transition on the negative edge of the clock (and stay high until the
following negative edge of the clock).
If I try driving the wr_req directly from the data source then both the
clock and wr_req transition at the same time and the memory doesn't get
the data.
How can I delay the write pulse such that it goes high (for one cycle)
starting on the next negative edge of the clock?
Guest #5229200
• ▲ useful
▼ not useful
If I understand your problem right, you want to drive a signal on the
falling clock edge. So just use the falling_edge (negedge in verilog).
If you don't mix it up in one process, you can create FFs which react on
either falling or rising clock edge (but not on both in most todays
FPGAs technologies).
if (falling_edge(clk)) then
  wr_req_to_ram_neg_edge <= wr_req_from_src_pos_edge;
end if;
I assume the data also has to be stable from negedge to negedge, so you
also have to sync the data on the negedge.
  • [vhdl]VHDL-Code[/vhdl]
