Higher voltage level on AnalogIN than AREF or intREF
Guest #5220245
I want to measure analog signals with an ATMega328.
For a better use of measurement range,
I switch to external reference and connect the AREF pin to a voltage
lower then 5 V (e.g. 1.1 V).
The analog signal is from a RTD.
The RTD is fed by a constant current source.
For normal conditions all is fine.
But if the RTD is damaged (resistance grow up like open RDT connection
line),
the constant current source rise up to a maximum value of 2.5 V.
Is that a problem for the ATMega, if on the analog IN is a voltage level
higher than the voltage an AREF pin?
additional question:
Same question but in case of use the internal reference (like in ATMega
2560).
Thank you.
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
