VHDL if construct assistance
Guest #5205510
Port w, x, y and z are defined as STD_LOGIC.
In my 'if' construct I use the below condition
if((not w) and (not x) and (not y) and (not z)) then
--Do something
instead of the actual proper syntax as below.
 if( w = '0' and x = '0' and y = '0' and z = '0') then
--Do something
The former implementation fails and returns the below error
type error near w ; current type std_logic; expected type boolean
I understand that VHDL is a strongly typed language and hence it returns
this error.
However consider a second case i.e. if i had to do an assignment c <=
not a (Where a and c are of type STD_LOGIC), the execution will proceed
without an error.
I am looking for a proper reason to give my students as to why the 'if'
construct fails but the assignment succeeds in VHDL.
Thank you.
Moderator (Company: Titel) #5205710
The "not" operator for std_logic gives a std_logic in return.
A "=" operator gives a boolean in return.
A "and" operator expects boolean operands.
With that information the behavior becomes clear.
#5212900
VHDL 2008 relaxes the overly strict behaviour and allows std_logic in
boolean context within if statements.
This can even be enforced with the '??'-Operator where this behaviour
would lead to ambiguity.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
