Verilog help
Guest #5191222
• ▲ useful
▼ not useful
Design algorithmic state machine comprising of controller and datapath
implemented in RTL based model, which can find how many times a virus
pattern equal to 1011 occurs in a data file (data files are to be
uploaded on the group).
a) Draw structural block diagram of controller and datapath along with
signals.
b) Draw ASMD chart of the state machine.
c) Give RTL level verilog description of controller (FSM) and datapath.
d) Design integrated test bench for the machine and verify your design
in simulated mode on provided test data files.
e) Verify working of the design on FPGA based development kit in the lab
on the given test data files.
Example for pattern matching: In pattern matching, a sequence is scanned
bit by bit and once a required pattern is found, the scan restarts from
the next bit. For example, we have 11011101011 in the data file, the
scanning process start from the left, we have 11 at that start (first
and second bit) that is different from the virus pattern (1011), since
it’s a mismatch, the scan starts form the second bit. Upon restarting
the scan from second bit, we have found that the virus pattern exists in
the next four bits, so the counter is incremented to one and the scan
restarts form sixth bit and this process continues until the end of
file.
Input phase: Data files that contains large strings of binary sequence;
is downloaded, either in the flash or in FPGA memory. Find it by you own
that how we do it on FPGA.
Output phase: A Reset button (pushbutton BTN0) that resets the value of
counter, and a Go button (pushbutton BTN1) that displays the counter
value (number of times the virus pattern 1011 exists in a data file) on
both seven segment displays (in decimal form) and on 8 LEDs (in binary
form). Considering the above example, the seven segment should display 1
as well as the LED should display the binary form of 1.
Is this code is valid for part (C) and i have bit stream in data file
how i can store this fie in my test bench
  CoDe
        VERILOG
CODE
module bat
#(parameter N=1, M=12 )
(input wire a,
    input wire clk,
    input wire reset,
    output wire y, z,
   output reg [2**M:0] c,c_new  );
   localparam [1:0]     s0 = 2'b00,
                                     s1 = 2'b01,
            s2 = 2'b10,
            s3 = 2'b11;
reg [1:0] state_reg, next_state;
reg  [N-1:0] b_reg[2**M-1:0];
reg [2**M-1:0] i;
  //State Register
  always @ (posedge clk, posedge reset)
  if (reset)
  state_reg <= s0;
  else
  state_reg <= next_state;
  //Next Logic
  always @ (*)
  begin
  case (state_reg)
s0 :
begin
 if (b_reg[i]==1)
next_state = s1;
else
b_reg[i] = i+1;
next_state =s0;
end
s1 :
begin
if(b_reg[i]==0)
next_state = s2;
else
next_state =s0;
 b_reg[i] = b_reg[i]+1;
end
s2 :
begin
 if(b_reg[i]==1)
next_state = s3;
else
next_state =s0;
b_reg[i] =b_reg[1]+1;
end
s3 :
begin
 if(b_reg[i]==1)
next_state = s0;
else
b_reg[i] =b_reg[i]+1;
next_state =s0;
assign c_new = c+1;
end
default : next_state = s0;
endcase
end
             //Output Logic
 assign y = (state_reg==s3) ? 1'b1 : 1'b0;                    // y is
for resetting value of counter
 assign z= c_new;
// z is for total counter value
endmodule
                                                            TEST MODULE
module t;
  reg a;
  reg clk;
  reg reset;
  wire y;
  bat uut (
    .a(a),
    .clk(clk),
    .reset(reset),
    .y(y));
always
  begin
clk=0;
 #100;
 clk=1;
 #100;
 end
  initial begin
reset = 0;
  a = 1;
  #100;
  reset = 1;
  a = 0;
  #100;
  end
  endmodule
  • [vhdl]VHDL-Code[/vhdl]
