32 bit data transmitt through rs232 protocol
OP (Company: google) #5155499
• ▲ useful
▼ not useful
I am new in VHDL programming. I have an output of counter of 32-bit
data. Now I want to transmit the 32 bit through the rs232 protocol which
can send 8-bit data once. I am attaching my UART file, DCFIFO of 32 to
8-bit mix file baud rate generator file and the counter file. Can
anybody help me how to port map them to get 32-bit data transmitted?
Guest #5165163
• ▲ useful
▼ not useful
I would suggest a state machine to control the transmisson:
type transmit_state_t is (IDLE, BYTE0, BYTE1, BYTE2, BYTE3, STOP);
constant STX : natural := 2;    -- start of text
constant ETX : natural := 3;    -- end of text
tx_enable      <= '0';
case transmit_state is
    when IDLE =>
        if new_data then
            tx_enable      <= '1';
            tx_data        <= to_unsigned( STX, tx_data'length);
            transmit_state <= BYTE0;
        end if;
    when BYTE0 =>
         tx_enable      <= '1';
         tx_data        <= data( 7 downto 0);
         transmit_state <= BYTE1;
    when STOP =>
         tx_enable      <= '1';
         tx_data        <= to_unsigned( ETX, tx_data'length);
         transmit_state <= IDLE;
end case;
30
31
I add STX and ETX to get a chance to synchronice the whole sequence on
the receiver.
Duke
  • [vhdl]VHDL-Code[/vhdl]
