gcc embedded cortex soft / hard float
Guest #5136361
Thanks in advance.
I'm using GCC to compile my Code for STM32F7 ARM Cortex.
Unfortunately my result always includes floating point emulation
Routines
00200664 00000254 T __aeabi_dmul
00200664 00000254 T __muldf3
00200300 00000276 T __adddf3
00200300 00000276 T __aeabi_dadd
002002fc 0000027a T __aeabi_dsub
002002fc 0000027a T __subdf3
Using the Compileflags:
CFLAGS_ARCH += -mlittle-endian -mcpu=cortex-m7 -mthumb
CFLAGS_ARCH += -mfloat-abi=hard -mhard-float -mfpu=fpv5-sp-d16
CFLAGS_ARCH += -D__FPU_PRESENT
How can I disable linking these Functions and see where and why they are
used in my Code to use only hard single Float?
If I just do -nostdlib it removes the full stdlib. I just want to use
the Hard FPU for performance instead of precise double precision.
Thanks !
#5137042
If I get you right, you try to tell the compiler to calculate double
values as float in hardware, right?
This raises the question why you use double in the first place if you
just want to calculate with float precision? Maybe you should use float
and be fine.
If you have no influence on the source you can check if you can tell the
compiler to do double with less precision (I'm not sure if this is
possible) or you can write your own implementation for the methods and
make the linker use them (I don't know how).
Start a new thread
