Libero V11.8 troubleshooting
OP (Company: ALE CO Ltd) #5129093
I am running Libero V11.8 with a Proasic3 A3P060-100VQFP attached to a
10MHz clock.
I am trying to get my first ever sketch running, it's extremely simple.
One input CLK, and 4 outputs LED (3 downto 0), the code is below, it
seems to check out fine.
It synthesizes with no problem, but then I go to set the I/O constraints
and run into a big problem.
I click on "Create/Edit I/O Constraints", it brings up the Designer and
the MultiView Navigator (see attached screenshot), it lists all the
outputs LED[0-3], but it doesn't list the CLK input.  Because it doesn't
list the CLK input I have no way of assigning it the onboard clock and
the program doesn't do anything.
How do I get it to allow me to attach the the input?  I tried renaming
CLK and even adding other inputs, but none of them appear in the
constraints editor.
I'm sure there is something simple I am missing, if anyone can point it
out I'd be grateful.
Thanks,
Josh
-- Company: <Name>
-- File: LED.vhd
-- File history:
--      <Revision number>: <Date>: <Comments>
-- Description:
-- <Description here>
-- Targeted device: <Family::ProASIC3> <Die::A3P060> <Package::100 VQFP>
-- Author: <Name>
library IEEE;
use IEEE.std_logic_1164.all;
entity LED is
port (
    CLK : in std_logic;
    LED : out std_logic_vector (3 downto 0)
end LED;
architecture architecture_LED of LED is
30
    signal pulse : std_logic := '0';
31
    signal count : integer range 0 to 9999999 := 0;
32
33
begin
34
   process(CLK)
35
    begin
36
        if (CLK' event and CLK = '1') then
37
            if count = 9999999 then
38
                count <= 0;
39
                pulse <= not pulse;
40
            else
41
                count <= count + 1;
42
            end if;
43
        end if;
44
    end process;
45
46
    LED (3 downto 0) <= (others => pulse);
47
end architecture_LED;
OP (Company: ALE CO Ltd) #5129100
Well...
I started the project over from scratch and when I went to assign the
I/O pins, CLK showed up and I was able to assign it to the onboard
clock.
The LEDs blink now.  Still no clue as to what I did wrong the first
time, hopefully the issue won't come up again.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
