Connecting Several Modules and a USB
OP (Company: UMASS) #5127968
Hello! I am trying to research side channel attacks on a 32-bit
architecture of AES and my very limited knowledge of circuits and of
Verilog is biting me in the behind.
I am trying to research some AES side channel attacks on an Artix-7 FPGA
via this board: https://wiki.newae.com/CW305_Artix_FPGA_Target
I am trying to put this version of AES on it:
https://github.com/secworks/aes
Specifically I want to use the USB / Register interface here:
https://github.com/newaetech/chipwhisperer/tree/master/hardware/victims/cw305_artixtarget/fpga
(Because it connects to the FPGA and I know it works)
More specifically the files "cw305_top.v", "usb_module.v", and
"registers.v". Again, here:
https://github.com/newaetech/chipwhisperer/tree/master/hardware/victims/cw305_artixtarget/fpga/common
And I want to replace the 128-bit architecture with the 32-bit one from
above, all files here:
https://github.com/secworks/aes/tree/master/src/rtl (Most notably
"aes_core.v")
Essentially I just want to get the 32-bit aes_core into the place of the
128-bit aes_core from above, where by 32-bit I mean something similar to
this:
https://www.researchgate.net/publication/254073694_A_Compact_32-bit_Architecture_for_an_AES_System
Thank you for any guidance or help in this. I am just so lost.
Thanks in advance,
Chris
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
