Gould Datasys 944A storage oscilloscope
Guest #5094660
Hello,
I have a Gould Datasys 944A storage oscilloscope with a serious battery
problem. All these scopes use a 3.6V Ni-MH battery on the cpu pcb board.
The battery leaks after a long time and the acid destroys the copper on
the pcb. I had stored this scope, which was working well, for 7 months.
I needed it
the last week and it was not working anymore. The battery had done his
work..
I removed the battery and cleaned the pcb. Several printline were
damaged.
I tried to solve it but it was nearly impossible to follow the
connections without removing several chips. I tried to find a service
manual on the net but didnt find it. Even a service manual from the 800
series is ok because it uses the same cpu pcb. I searched again on the
net and found a link in the States, who had sold Gould there, but he
couldnt help me.
An old collegue had a Gould Datasys 840 which he does not use anymore.
I got the scope and the operating manual, but no luck..The same problem
with the battery and the cpu pcb even worse : the memory chips fell off
the board when you touch them.
So if anyone has a service manual for the 800 or 900 series please let
me know. I will pay for it!
The only thing i could do now is desoldering some IC from the 800 board
to follow the broken lines on the 900 board.
If you have a working Gould scope move your battery from the CPU pcb to
somewher else...
Start a new thread
