Moving a selected group in EAGLE
Guest #5078492
Hello,
I have an incomplete Layout in a limited version of EAGLE. I already use
up all of the available space, so moving the Board boudaries is not an
option.
Due to a misjudgement of space I need to move a selectable group of
carefully aligned parts (mount holes for a display, buttons, display).
Is there a way to tell Eagle to move the entire group, lets say 10mm to
the left? I dont want them to move up or down, as could accidentally
happen when I use my mouse. I have seen something like this in other CAD
Software, where you could use the arrow-keys and type in the distance.
Guest #5078633
Simply GROUP your components, then set the grid to 10mm, finally MOVE
the group. Since the grid is set to 10mm, its fairly easy.
Guest #5078640
You can also use the command line for this.
GROUP the components using the mouse, then type in the command line
move (> 0 0)
This will select the group in the origin 0 0
(10 0)
This will drop the group at the coordinates 10 0
This way you can move a group easy and precicely by any offset.
Start a new thread
