Give Me Suggestions about PIC16F1509
OP (Company: none) #5033789
Good day,all
I am currently involving in a project by using PIC16F1509.( the
PIC16F1509 PDF:
http://www.kynix.com/uploadfiles/pdf8798/PIC16F1509-E2fML.pdf ) I
compiled it pass hi-tech9.83. However, there are about 100 lines can’t
compile into the 8K room. The direct compile can’t be passed because the
room to save codes is not enough.
Can anyone give me some feasible suggestions so that I needn’t choose
chip again.
Please give me some advice in choosing compiler, code optimization or
coding !
Thanks again !
Best regards~
Guest #5033802
Is your entire code just 100 lines? The only way to fill 8kB with 100
lines of code is to use expensive library functions like printf() or
floating point math. You should avoid these. But it's hard to help
without seeing your code.
Guest #5033820
Without showing us you code, it's nearly impossible to give good advice
how to save code.
One idea ist to put some identical blocks of code into a subfunction.
What optimization setting of HiTech 9.83 do you actually use?
Do you have free version ("Lite mode") or "Pro" version (not free, you
have to pay for). The "Pro" version does higher optimization.
See:
http://www.microchip.com/forums/m731823.aspx
Yours
Start a new thread
