LVDS Controller LCD Panel
Guest #5008930
Hello you great people,
I´m searching for a possibility to connect a big old LCD panel via
HDMI/VGA/DVI.
The panel is from IPS Alpha Technology and has the number AX094F040E.
The datasheet i found sadly is only for similiar model:
http://www.datasheetspdf.com/mobile/905021/AX094F002G.html
Is there a simple way to find a matching controller board or if not
availible could you tell me the way to go deeper and maybe finding
another solution?
There is also the T-Con Board and the power supply of the old TV still
screwed on the back, can this mabybe help?
Since i´m currently at the start of my bachelor in electrical
engineering, i´m motivated to get it done ;)
But the game is not worth the candle please tell me that!
I appreciate any kind of help.
Thank you a lot,
nairolf_sch
Guest #5008944
Take this one :
http://www.ebay.de/itm/M-NT68676-2A-HDMI-DVI-VGA-AUDIO-LCD-LED-Controller-Board-Kit-LVDS-DIY-2048-1152-/271175654997
Try to find one with programming kit. This board can be programmed via
vga connector. Or build one by yourself its just simple rs232 as far as
i remember. This way you will be able to flash the controller with any
display config you desire.
It does not support hdcp, but there is a workaround with hdmi-splitters
from china, just google for it ;)
Good luck
Tom
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
