Assignment under elsif does not work
OP (Company: Bilkent Uni) #5000373
Hello everyone,
I am developing a brick breaking game in VHDL. For this project, I have
successfully implemented a image generator and a VGA synchronizer.
However, I am having problems with the game logic. In this game, bricks
are supposed to be destroyed when the ball hits. When a collision is
observed, the ball should change its direction. So as to realize this, I
wrote the following code:
    process(refresh_tick,ball_x,ball_y,xv_reg,yv_reg)
    begin
         ball_x_next <=ball_x;
         ball_y_next <=ball_y;
         xv_next<=xv_reg;
         yv_next<=yv_reg;
         if refresh_tick = '1' then
           if ball_y> 400 and ball_x > (bar_l -ball_u) and ball_x < (bar_l +120) then --the ball hits  the bar
               yv_next<= -y_v ;
           elsif ball_y <= 0 then--The ball hits the wall
               yv_next<= y_v;
           elsif ball_x <= 0 then --The ball hits the left side of the screen
              xv_next<= x_v;
           elsif ball_x >= 640 then
              xv_next<= -x_v ; --The ball hits the right side of the screen
           elsif is_ball_on_bricks_area and bricks_collection(current_brick_row, current_brick_column) = '1' then
              yv_next <= y_v;
              bricks_collection(current_brick_row, current_brick_column) <= '0';
           end if;
           ball_x_next <=ball_x +xv_reg;
           ball_y_next <=ball_y+yv_reg;
        end if;
    end process;
In this game, I define bricks as a 2D array:
    type brick_array is array (0 to 4, 0 to 9) of std_logic;
    signal bricks_collection : brick_array := (others => (others =>
'1'));
So, when a collision is detected, the destroyed brick is assigned as '0'
and ball change its direction yv_next <= y_v; Unfortunately, only one of
them is executed during the run time which is at this case
bricks_collection(current_brick_row, current_brick_column) <= '0';. I
know that the logic I came up with works, that is, collisions are
detected successfully.
These statements under the last elsif statement should be run
concurrently. But they are not. How do I make them run concurrently?
So I know that in a process if I do something like this, the second
assignment takes place at the second clock tick:
    process(clk)
    begin
    a <= b;
    b <= c;
    end process;
Is this a similar problem?
Guest
firstly, please use vhdl formatting in this forum.
secondly, complete your sensitivity list with all used signals like
"is_ball_on_bricks_area,x,x_v,y_v,.."
Thank you for your reply. I can not go back and change the formatting.
Sorry about that.
I added is_ball_on_bricks_area to the sensitivity list. However, x_v and
y_v are constant which are determining the speed of the ball. That is,
if y_v is 3, ball goes down. If it is -3, the ball goes up.
So let me repeat the problem in different words.
              yv_next <= y_v;
<= '0';
Here, if I remove bricks_collection part, yv_next <= yv part is executed
correctly. However, when I keep it as it is, which I should, only the
second assignment takes place.
Guest
current_brick_row and current_brick_column look also like no constants,
try to add them also to sensitivity list.
also there is bricks_collection only defined in one arc which will lead
to latch behavior. I dont know your code and cannot say if this was
intended.
Moderator (Company: Titel)
bricks_collection has to be in the sensitivity list also. But that will
not help that far, because this is a very dirty tricky trick here:
              yv_next <= y_v;
           end if;
Here we have a asynchronous reset on bricks_collection and therefore a
latch. Usually latches are a very bad thing, because mostly they
happen accidentially. In your design this is (like nearly always) due to
the 2-process coding style.
In other words: bricks_collection is storing some information. Storing
elements in a FPGA should be flipflops. Therefore there should be
something like a bricks_collection_next (like all of the other
flipflops). And that bricks_collection_next then must be written to
bricks_collection with the (one and olny) clock (like all the others).
BTW just one question: why do you use a process for that all?
It could be easily done concurrent...
Thank you so much. Indeed, latch behavior was not intended.
I was able to solve all my problems by introducing the register logic
once more.
Miller, before starting on this project, I read few articles, reports,
and went through some examples of similar games. I saw that they are
using so-called 2-process design method. Therefore, I adapted a similar
approach. However, I have never thought "latch behavior" could lead to
prevent assignment of y_v to yv_next and I have yet to understand the
reason behind that.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
