qsys and user design
Guest #5000111
hi everyone,
I am a beginner , i would like to know whether it is possible to connect
qsys component + user design and successfully synthesis in an altera
fpga. if yes, i see sop,pos and ready signals at qsys modules. how to
deal with these signals. should i simply write a logic to decode these
so that my design understands it.
my task is->
test pattern generator(qsys ip )-> edge detect(my design)->clocked video
output(qsys ip)->displayport(qsys ip).
looking for your inputs:)
Guest
Why on earth would you want to use the Qsys crap as a beginner? (pardon
my bluntness). Start small, keep it simple and remember that your best
friend is a robust simulator. Qsys might pay off at a point where you
need to integrate a complex CPU, but even that is questionable.
Guest
...can you put your edge detect design in a qsys component and insert
this into your existing qsys system. You probably want to give that
component a avalon master or slave interface or some conduits, depending
on your design, so it can interact with the other qsys components via
the avalon fabric. I dont say it is easy but that would probably work.
BUT implementing a video and pattern generator is not so hard to do
without the qsys stuff. There are dozens of example designs for that to
get some inspiration how this can be accomplished.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
