Altera ALTCHIP_ID
Guest #4988710
Hi Folks,
I'm just playing around with the ALTCHIP_ID block that is available in
the recent Altera FPGAs. This block returns a unique ID identifying the
chip. The returned value has 64 bits. For my application I should have
less than 64 bit but still have a very low chance of collisions between
the numbers. So I wonder which bits I can leave away safely because they
will be identical on all devices of the same type.
I checked about 20 MAX10 FPGAs and found that the chip-IDs differ only
in bits [16:4]. All other bits in my small lot are the same. So it seems
save to cut away the upper range [63:32]. But this is only an assumption
and I would like to be more certain about that.
Does anyone know how this unique number is composed by Altera. Are any
of these bits representing information like vendor or device type which
would be constant for all devices of a given type and could be safely
cut away for my application?
Thanks,
Andi
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
