PS/2 module with LCD
OP #4985729
Hello, I have this project where I have to interact with the PS/2 module
(a keyboard) and when I type the letters in the keyboard those must be
shown in the LCD of the board.
I made a state machine where I tried to said that when I type a letter
it must be held in a register until I let the button go and compare the
break code with the letter registered and then that data must be gone to
a case block where I wanna put all the possible cases of the letters to
be shown in the LCD display.
But it doesn't work, it is recognizing the letter typed because I
connected it to a 6-seg display, but the LCD doesn't show anything, can
anyone help me?
Guest #4985816
OK, i don't know verilog, sorry.
I would look at the Display-Datasheet and at the IO-Connections of
Display and FPGA, how is ist connected? Parallel Bus or serial
Interface? Which commands must be sent? Are the Voltages correct?. So
first try to display any static Character on the Display.
Moderator (Company: Titel) #4986287
And then I would try to read a key (scancode) from a PS/2 keyboard.
And then I would convert the scancode to an ASCII character.
And then I would hand over that key to the display component.
So the most important process is to split up the "big problem" in
several "small problems" that can be solved each one after (and
independent from) the other. The debugging on this level is done solely
by the simulator.
And when each one of that designs is running stand alone (at least in
simulation, better if on real hardware also) , then it is fairly simple
to connect them together to one big design.
This process is called "Divide et impera".
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
