Not a homework question, I am 58 1/2!
OP (Company: Relevant Technologies Ltd) #4972293
Hi Everyone
I am using the ARM AXI4 stream data interface to create blocks as part
of a telemetry data tranceiver. Being a complete newbie (software
background), I am making a total meal of this. I need to know if there
is a generic solution to receiving data, processing it with arbritrary
latency (BRAM access, pipelined calculations, that sort of thing), and
transmitting the result of the processing. The whole thing must be
stallable at both ends, obviously.
My best approach to date has been to separate the input and output
processes, using a ping-pong buffer in BRAM. I get the feeling this is
the trademark of a kindergarten amateur (it has a latency of one block,
for instance) and would like to know a better way.
The stream interface is as simple as can be, Tx valid and Rx ready
signifying a transfer has been executed, Tx valid being obliged by the
protocol to remain asserted until Rx Ready acknowledges. In general, an
output needs a number of input words for its construction, and its
calculation may additionally need to be pipelined. There must be some
pretty obvious way of stalling the input bus when the output bus is
unavailable, but nothing comes to mind which enables me to separate the
processing of input data from the generation of output data. I want to
be able to get on with receiving and crunching as much input data as is
needed to generate the next output while waiting for the output bus to
accept the last requested transfer. Rx ready is allowed to be a random
value, with no protocol constraints save that if it asserted
simultaneously with Tx Ready the acceptance of data is implied.
This must be a basic technique, and would seem to lend itself to
reuseable code. Anybody know of a good book?
Best regards
Geoff
Saluti, Best regards
Geoff
Guest
Your approach doesn't sound like a stupid idea.
What about using a dual-ported BRAM as a FIFO, with dedicated input and
output ports? Your input process constantly writes into the BRAM (until
the buffer is full, at which point it stalls), and your output process
constantly reads from the BRAM (until the buffer is empty, at which
point it stalls).
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
