Reconfigure MachX02 using Wishbone
Guest #4914130
I'm trying to build a self-updater for the configuration of a MachXO2.
It uses the EFB via Wishbone to reprogram the Configuration memory.
I'm able to successfully read the USERCODE using the interface as well
as causing a REFRESH.
When I try to enter the configuration mode using the "74 08 00 00"
command neither the fail bit nor the "configuration mode enabled" bit
will be set. Also the busy bit is never set to one which it should
considering the documentation says that you should wait 200us (or poll
the busy bit).
I was not able to find any errors in my code after several days of
debugging, so I think there must be some problem with the sysCONFIG I am
using. Does the default configuration not allow reconfiguring the
internal flash? And if so, what do I have to change?
Anyway, I have attached the code I am using. Sorry, comments are in
German and there is some debug logic in it.
I really hope someone has successfully done this before and could geive
me some advice.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
