DMA with AXI lite interfaces
Guest #4886763
Yes this works.
In a project i'm using an axi lite slave peripheral and a second
hardware Block with full axi which is connected to the PS slave port is
copying the data from the axi lite regs to ddr ram.
In Vivado HLS it is quite easy to implement a dma engine with full axi
and bursts.
OP (Company: sssihl) #4886950
Hi
Thanks for the reply.
Suppose if I generate an IP core (with AXI lite interface) using Xilinx
system generator design flow, still I should be able to use DMA, right?
Thanks in advance
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
