Forum: Mikrocontroller und Digitale Elektronik CC1101 + Arduino + panstamp libary fehler
von Jannis P. (janpeter)
Moin!
Ich versuche derzeit meinen CC1101 zu flashen. Der Sender hat folgenden
Code:
#include "EEPROM.h"
#include "cc1101.h"
CC1101 cc1101;
#define LEDOUTPUT 7
// counter to get increment in each loop
byte counter;
byte b;
byte syncWord = 199;
void blinker(){
     digitalWrite(LEDOUTPUT, HIGH);
     delay(100);
     digitalWrite(LEDOUTPUT, LOW);
     delay(100);
void setup()
 Serial.begin(38400);
 Serial.println("start");
 // setup the blinker output
 pinMode(LEDOUTPUT, OUTPUT);
 // blink once to signal the setup
30
 blinker();
31
32
 // reset the counter
33
 counter=0;
34
 Serial.println("initializing...");
35
 // initialize the RF Chip
36
 cc1101.init();
37
 cc1101.reset();
38
 cc1101.setSyncWord(&syncWord, false);
39
 cc1101.setCarrierFreq(CFREQ_868);
40
 cc1101.disableAddressCheck();
41
42
 Serial.print("CC1101_PARTNUM "); //cc1101=0
43
 b=cc1101.readReg(CC1101_PARTNUM, CC1101_STATUS_REGISTER);
44
 Serial.println(b);
45
 b=cc1101.readReg(CC1101_VERSION, CC1101_STATUS_REGISTER);
46
 Serial.print("CC1101_VERSION "); //cc1101=4
47
 Serial.println(b);
48
 Serial.print("CC1101_MARCSTATE ");
49
 Serial.println(cc1101.readReg(CC1101_MARCSTATE, CC1101_STATUS_REGISTER) & 0x1f);
50
51
 Serial.println("device initialized");
52
53
54
void send_data() {
55
CCPACKET data;
56
 data.length=1;
57
 byte blinkCount=counter++;
58
 data.data[0]=blinkCount;
59
60
s Serial.println(cc1101.readReg(CC1101_MARCSTATE, CC1101_STATUS_REGISTER) & 0x1f);
61
 if(cc1101.sendData(data)){
62
   Serial.print("sent ok :)");
63
   blinker();
64
 }else{
65
   Serial.print("sent failed :(");
66
   blinker();
67
   blinker();
68
69
70
71
void loop()
72
73
 send_data();
74
 Serial.println("loop done");
75
 delay(1000);
76
Wenn ich auf Flashen klicke kommt er aber nicht mal durchs kompillieren.
Folgende Fehlermeldung:
Sketch wird kompiliert...
"C:\Users\Jan\Desktop\arduino-1.8.0\hardware\tools\avr/bin/avr-g++" -c -g -Os  -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10800 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Users\Jan\Desktop\arduino-1.8.0\hardware\arduino\avr\cores\arduino" "-IC:\Users\Jan\Desktop\arduino-1.8.0\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\Jan\Desktop\arduino-1.8.0\hardware\arduino\avr\libraries\EEPROM\src" "-IC:\Users\Jan\Desktop\arduino-1.8.0\libraries\panstamp" "C:\Users\Jan\AppData\Local\Temp\arduino_build_460993\sketch\CC1101-Senden.ino.cpp" -o "C:\Users\Jan\AppData\Local\Temp\arduino_build_460993\sketch\CC1101-Senden.ino.cpp.o"
In file included from C:\Users\Jan\Documents\Arduino\CC1101-Senden\CC1101-Senden.ino:3:0:
C:\Users\Jan\Desktop\arduino-1.8.0\libraries\panstamp/cc1101.h: In function 'void setup()':
C:\Users\Jan\Desktop\arduino-1.8.0\libraries\panstamp/cc1101.h:306:10: error: 'byte CC1101::readReg(byte, byte)' is private
     byte readReg(byte regAddr, byte regType);
CC1101-Senden:44: error: within this context
CC1101-Senden:46: error: within this context
30
31
32
33
34
35
36
37
38
39
40
41
CC1101-Senden:50: error: within this context
42
43
44
45
46
47
C:\Users\Jan\Documents\Arduino\CC1101-Senden\CC1101-Senden.ino: In function 'void send_data()':
48
49
CC1101-Senden:61: error: 's' was not declared in this scope
50
51
52
53
54
55
Bibliothek EEPROM in Version 2.0 im Ordner: C:\Users\Jan\Desktop\arduino-1.8.0\hardware\arduino\avr\libraries\EEPROM  wird verwendet
56
Bibliothek panstamp im Ordner: C:\Users\Jan\Desktop\arduino-1.8.0\libraries\panstamp (legacy) wird verwendet
57
exit status 1
58
within this context
Kann mir jemand helfen was ich falsch mache? Googlen hat leider kein
Erfolg gebracht :/
Danke!
von Arduinoversager (Gast)
Nein, ich kann dir nicht helfen. Denn diesen Baustein
kann man nicht flashen da er gar kein Flash hat.
Aber vielleicht kannst du die Features hochskillen dann
kann man ihn vielleicht doch flashen.
von Kaj (Gast)
Was der Fehler ist, steht da doch:
Du benutzt eine private Funktion ausserhalb der Klasse.
Kaj schrieb:
> Was der Fehler ist, steht da doch:error: 'byte
Hey danke für die Antwort!
D.h.:
in den dateien
#include "EEPROM.h"
#include "cc1101.h"
die ich aus der Libary ziehe ist dann irgendwas falsch deklariert bzw
nicht passend für meinen Sketch?
Ich schau mal ob ich ne andere Version der Libary finde oder das
bearbeiten kann.
von aufmerksamer Leser (Gast)
Jannis P. schrieb:
> D.h.:
> in den dateien
> #include "EEPROM.h"
> #include "cc1101.h"
Dein Sketch benutzt Funktionen, die nur bibliotheksintern verwendet
werden sollen. Das, was Du da abbilden willst, muss anders gehen. Am
besten die Doku zur Bibliothek noch mal lesen und den Sketch umschreiben
Natürlich kannst Du diese Funktion in der cc1101.h auch aus "private" in
den Bereich "public" ziehen, das ist aber ein übler Hack.
von Nixversteher (Gast)
aufmerksamer Leser schrieb:
> Am besten die Doku zur Bibliothek noch mal lesen und den
> Sketch umschreiben
Copy & Paste Maker verstehen nicht eine Doku zur Bibliothek,
sie wissen auch nichts von einer Klasse, geschweige denn
was Public oder Private ist. Deswegen ist jeder Ansatz, Hilfe
zur Selbsthilfe zu geben, sinnlos. Das sollte bereits aus
dem ersten Satz erkennbar sein:
von Kaj (Gast)
Nun, das kann man jetzt sehen wie man will.
Entweder man sieht es so wie du, naemlich dass in dem Code der "Lib"
etwas falsch ist. Oder man betrachtet es so, dass Du die "Lib" falsch
benutzt, naemlich nicht so, wie sich der Entwickler der "Lib" das
gedacht hat.
Letzteres ist die verbreitetere Ansicht da man davon ausgehen kann, dass
sich der Entwickler der "Lib" (hoffentlich(!)) etwas dabei gedacht hat.
Um das Problem zu verstehen muesstest du dich mal ganz kurz mit OOP, C++
und Klassen beschaeftigen.
Ich hab mal kurz in die Headerdatei reingeschaut:
https://github.com/raimue/arduino/blob/master/libraries/panstamp/cc1101.h
Hiernach ist die entsprechende Funktion public und sollte aufrufbar
sein.
Abgesehen davon ist das Teil aber, wie bei nahezu allem Arduino-Code,
einfach ein grauss...
von Kaj (Gast)
Ich hab deinen Code gerade mal versucht zu compilieren...
Ich weiss nicht was das 's' da am Zeilen anfang macht, aber das gehoert
da nicht hin. Wenn ich das 's' da entferne dann compiliert der Code bei
mir. Gibt zwar einen haufen Warnungen, aber es compiliert.
> gedacht hat.
Kann durchaus sein, da die panstamp Lib ja eigentlich für das
Panstamp/Stick board gedacht ist. Jedoch nutzen viele diese Libary für
ihren CC1101 also sollte das auch gehen irgendwie. Also ist es wohl der
Code. Dieser scheint jedoch bei anderen Usern zu funktionieren. z.B. bei
dir.
> sein.
Ja dieses erstellen der Sketche im ArduinoEditor ist schon etwas schräg
irgendwie weil man nur eine Datei hat und irgendwie keine Übersich wie
bei z.B. Eclipse usw.
Keine Ahnung woher das "s" kommt. Kompillieren tut er bei mir trotzdem
nicht :/
Fehlermeldungen sind die gleichen, nur die mit dem "s" fällt weg
natürlich.
Danke aber schonmal für die Hilfe!
