Clock manipulations without DCM
OP (Company: None) #4866298
Hi, I'm Mark and I'm a VHDL newbie.
I need to generate 2 different signals from a 100 Mhz clock:
The first one will have 78 Mhz frequency and 50% Duty Cycle.
The second one 78 Mhz f and 70% DC.
I can't use DCM for this, just counters.
I attached a vhd source with a clock filter, I used this to get a 25 Mhz
signal from a 100 Mhz clock with 50% D.C. It works fine, but it won't
work as expected if the division between frequency_in and frequency_out
is near 1, like in the 100/78 case.
Moderator (Company: Titel) #4866707
Clocks in FPGAs are generated by clock managers. Always.
That jittery derivative (named clock_out in your case) generated with a
counter may be used as clock enables, but never ever as real clock.
Just read the manual of your FPGA. Chapter "Clocking".
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
