Forum: PC-Programmierung Enhancing Code Efficiency in C++
von Greg B. (gregbowers)
Hello
I'm currently working  in a C++ project and I'm excited to explore
methods for optimizing code efficiency. My aim is to confirm that my
code runs as efficiently as possible while maintaining readability and
ease of maintenance.
I would greatly appreciate any suggestion for enhancing the performance
of C++ code. Specifically, I'm interested in learning about techniques
for boosting runtime performance and minimizing memory usage , Common
errors to watch out for and how to avoid them to prevent inefficient
code.
Recommendations for tools and approaches to identify and resolve
performance issues effectively.
Strategies for writing code that is both efficient and well-structured
for future maintenance.
Whether you're a experienced  C++ developer or have valuable insights to
offer, I'm eager to learn from your experiences .
Thank you in advance !
von Bruno V. (bruno_v)
Do not help the compiler: straight code, no tricks.
Enable highest Compiler Optimization.
If you want to rewrite Code, check that it really is a bottleneck, then
ask specifically again.
Greg B. schrieb:
> My aim is to confirm that my code runs as efficiently as
> possible while maintaining readability and ease of maintenance.
Maintaining readability and ease of maintenance is much more important,
than performance. Optimize performance only if really necessary, and
only where necessary.
If you optimize your code for low CPU/memory manually, you waste a lot
of time and risk to introduce new problems. The next larger/faster
computer is often the better option (easier, cheaper, faster to get,
better to maintain).
is mainly the job of the compiler. After a while, you will learn to
avoid some very bad things. For example manipulating large strings to
produce a HTTP response can often be replaced by a sequence of shorter
writes. Reading the same data repeatedly from an external source may
benefit from a cache (which might be a simple array or hash-map).
For PC and servers I can recommend Dynatrace. It helps you a lot to find
the hot spots, even in a productive environment. Wait until you have a
real bottleneck, then try their demo. https://www.dynatrace.com
von Rbx (rcx)
Arbeite einfach die bekannten Bücher durch. Da kannst du eine Menge
lernen.
Darüberhinaus sind so allgemeine Fragen eher ineffektiv, viel besser ist
es, direkt problematische Code-Abschnitte zu zeigen.
Du würdest dich sehr wundern, was da so alles geht ;)
von Harald K. (kirnbichler)
Premature optimization is the root of all evil.
von Oliver S. (oliverso)
Anders kanns ChatGPT halt nicht.
Oliver
The question might have a historical reason.
In the '80s a good programmer had to know how to optimize source code
for the limited machine.
But in the meantime, the compilers became much better, and the computers
became 1000x more powerful.
Now we can quickly develop huge programs that get out of control due to
their complexity. Read about the KISS priciple!
Na ja, wie immer kommts auf die Anwendung an. Manchmal reicht KISS nicht
aus.
cppcon hat da ein paar sehr nette Beispiele. So wie das hier:
https://youtu.be/NH1Tta7purM?si=zCVdc6cYjAfbcSZH
Oliver
von Norbert (der_norbert)
Das war auch mein erster Gedanke!
Mittlerweile scheinen die LLMs ja proaktiv das Netz abzugrasen.
Und sie haben auch schon gelernt welche Vornamen man benutzen muss um
instantan Welpenschutz zu erhalten.
von Falk S. (falk_s831)
Well, ok, just the quest for the holy grail, nothing less than that.
Good luck!
> code.
Well, as someone said in this thread before in different words:
optimization is just the last 1%, the remaining 99% are driven directly
by your technical architecture. First spot to search for optimizing
speed of your software is there. If there's no room available in there -
well, there's only one thing possible to do: profiling your code and
find the performance weak spots.
Do MISRA-C++, and this is meant seriously. It might help you writing
clean code and will punish you for doing magical, tricky programming
style. Do apply Google C++ coding style. Learn Clean Code C++
development somewhere.
But don't primarily focus on writing the fastest code on the planet. If
you want to go that way, learn to program Commodore C64/Amiga demos in
Assembler :)
von Johann L. (gjlayde) Benutzerseite
Of course you can help the complier; provided the compiler allows
contribution.
The compiler is the key point when it comes to producing efficient code.
Hence the place to go is the compiler.
von Frank O. (frank_o)
Da müsste man erstmal die Fähigkeiten kennen. Außerdem müsste man die
Plattform kennen. Ein Code für eine ATmega328 sollte beispielsweise
keine komplexe Mathematik enthalten, während das auf einem Intel i7 kein
Problem ist.
Wenn du noch nicht den Startpunkt, den Weg, sondern nur das Ziel
definieren kannst, solltest du erst dort anfangen.
Yes, but current compilers are the last point where additional
optimization makes sense, because they are all already very good.
C++ bietet natürlich von seiner Architektur her auch grandiose
Möglichkeiten, hochineffizienten Code zu schreiben - da sich auch hinter
Dingen, die aussehen wie simple Zuweisungen, hochkomplexe Funktionen
verbergen können, muss man also wissen, was der Code tut, den man da
so hinschreibt.
Gerade beim so beliebten Einsatz fremden Codes (sei es in Form eines
"Frameworks", einer Klassenbibliothek oder was auch immer) kann sich
hinter einer simplen Fassade erstaunlich komplexes verbergen.
Es empfiehlt sich daher, fremden Code nicht einfach zu verwenden,
sondern auch mal reinzusehen und nachzuvollziehen, was der so treibt.
Both of you are right: the TO should focus on basics, because experts
like Johann contributed to compilers, the key part for efficient Code
von Rbx (rcx)
Übrigens sind die Bethesda-Leute auch immer so aufgeregt, was sie wieder
"aktuell" zusammengecodet haben.
Jetzt sehen die vor lauter Aufregung aber gar nicht mehr den
Scherbenhaufen, den sie angerichtet haben.
-> mal runterkommen von dem Trip, etwas entspannter werden, und mit
nüchternen Blick auf die Situation schrittweise Hindernisse und
Missverständnisse abbauen.
von Jens M. (schuchkleisser)
Mich wundert das noch keiner gesagt hat, das man für wirklich
effizienten kleien schnellen Code nur Assembler nutzen kann.
Und das dann das Geschrei los geht ach wie toll doch Compiler sind.
Und der Witz des ganzen ist, das beide Seiten recht haben, je nach
Maschine und Situation.
Verstehen heißt das zauberwort.
Stichwort Sicherheitslücken, was bedeutet je nach Anwendung des Ganzen
kann man fremder Leute Code gar nicht einsetzen, aber Dank Scrum und
Konsorten muss man weil man sonst nicht fertig wird.
Resultat: großer lahmer Code mit unwartbarem Fremdcode und dadurch
unstopfbaren Sicherheitslöchern.
Oder 5-Minuten-Arduinoprojekte, die einfach tun.
Yes.
No.
Just have a look at the compiler generated code: still the same
bullshit.
> and the computers
Yes, but the resulting application programs still run as slow. That's
because the developer stops optimizing, if the small samples he tries on
his powerful development machine runs barly fast enough.
Greg B. schrieb:
> My aim is to confirm that my code runs as efficiently as possible
You do this by looking at the machine instructions that are executed to
solve the problem - including error checking.
If no instruction can be omitted to solve the given problem, even after
reordering, than your implementation is as efficient as possible (given
the selected algorithms). Ok, additionally considering the impact of the
cache on instructions and operands.
And IT IS possible to write a program in C and even in C++ that only
executes the strictly neccessary instructions. You just have to check
what your coding practice and structure generates on the machine level.
A lot of work, but possible. A C++ program does not need to be slower
and bulkier than a C program. Only use the handy language constructs
when they are contributing for good.
Programs become slower faster than computers become faster, isn't it?
So, bascially, you say i should write in C but check und understand what
the compiler does in assembly, and optimize the C so it gives perfect
assembly?
Then why not write in assembly directly? I'll only need to learn one
language, need only to check and understand one language and can use the
IDE much more efficient.
If you really want
than you should do it.
Readability may also gained in assembly using comments.
But most people today are too lazy to write large assembly programms and
are able to keep track of the program as a whole.
Lets say your overview extends only to a certain amount of lines of
code, let it be 300 for beginners or 3 million for experts. Than your
C++ program may tackle larger problems than your assembly code
No. I don't want my 286er back.
Because programming complex programs in assembly takes much more time.
Also assembly does not support you in structuring large programs. You
are a very lucky man if you find a patreon who pays you for that.
It' not a question if laziness. We (programmers) are artist, but we need
money to live, like all others as well.
By the way: I won an assembler contest long ago. The most beautiful
Screensaver below 1k. My was only 99 Bytes.
I don't, too.
But you can't deny that programs become bigger and bigger, Linux the
same as Windows the same as every application that is around for some
time.
And especially when you try new versions of OS's on the same machine you
can not ignore that the newer version can do more, but mostly useless
stuff, and gets a lot bigger and slower.
Michael B. schrieb:
> If you really want
You said that, basically ;)
Yup. It was a reply to Michael B. that said "you should check your C to
see what it does in assembly, and optimize the C so that the assembly is
best", and so i said why not write assembly directly?
C is there for a reason...
So, it's the BWLers, as always... :D
Funky how we treat the AI request of the OP as a leader and reply in a
foreign language on a german forum.
Not that ucnet has a english sister forum...
von Tilo R. (joey5337) Benutzerseite
Use efficient algorithms.
Not trying to do what the compiler does better anyway, perhaps may
decrease performance by 10%.
Choosing an inefficient algorithm may decrease performance by a factor
of 10.
Or more. And the compiler won't help you.
von Ein T. (ein_typ)
So basically this is about performance optimization. On that, there are
three famous quotes you should know:
1. "Premature optimization is the root of all evil." (Donald E. Knuth)
2. "Make it work, make it right, make it fast." (Kent Beck)
3. "Measure, don't guess." (Kirk Pepperdine)
This said, what you're asking for is generally a bad idea, for what
you're trying to accomplish is in fact premature optimization. But until
you have at least something very similar to your final application,
there is no way to predict its runtime characteristics (unless, maybe,
you are a genius).
In the end, you first need something that is "right" in the sense of
Kent Beck's quote, that is it basically should correctly do what it's
supposed to. Then and only then you have something that you can measure
(or "profile") to answer questions, the first of which should be: Does
your program meet its performance requirements?
If it does, everything is fine and you're done. If not, then you can
profile your program and gain insights about its runtime
characteristics, such as: which function or method takes which amount of
runtime, which data structure uses most of the memory, where does your
program spend most of its runtime? Spending time on the optimization of
programs that meet their requirements is a total waste of time.
Then, you should be clear about the direction of your optimization.
Often you can trade one thing such as memory comsumption against another
thing such as cpu usage or runtime, that is: your program might require
less memory but use more cpu cycles instead, or vice versa. You also
might keep in mind how your program interacts with the underlying
operating system and your hardware. For example, the dynamic allocation,
reallocation and deallocation of memory (library functions malloc(3) and
free(3), system calls brk(2) and mmap(2)) will each require two context
switches. On modern operating systems context switches are an expensive
operation, thus -- depending on your use case -- it might be more
efficient to once allocate all of the needed memory size rather than
allocating lots of small memory chunks. In other use case you might want
to save memory, the allocation of smaller chunks might be more
efficient.
You might find that your program takes most of its time for disk or
network I/O, which is common for programs that don't do a lot of complex
calculations or programs that do calculations on big amounts of data.
Unfortunately, most of the time there is not much you can do about that,
because disks and networks are the slowest parts in your computer and
improvements are hard to achieve without switching to other
technologies, eg. replace your HDDs with SSDs or SSDs with NVMe devices,
or pimp your network from 1 gigabit ethernet to, for example, 10 gigabit
ethernet. Depending on your use case, such improvements might be
expensive and thus maybe not profitable. (Don't stick to this point,
it's just an example here).
Then you might find that some methods or functions either take a lot of
time because they are called very often or because their algoritm is not
efficient. These functions or methods are the best and sometimes even
the only candidates where you can significantly improve performance, and
here you have the reason why it's so important to measure (or "profile")
first. Different compilers, compiler settings and even compiler versions
might use different strategies for their optimization. Non-trivial
programs, that is: programs that do real work, you can never predict
what the compiler and especially its optimizer will make out of you
source code. So measure, don't guess.
This said, what can you do in the early stages of development? Well,
think about your program, especially about its algorithms and data
structures. There are good reasons why the C++ Standard Template Library
has (for example) multiple map containers, such as std::map and
std::unordered_map. Both have different performance characteristics for
different use cases, so learn about these characteristics and choose the
container with the best fit for most of what your program uses.
Every other approach you might try will have negative impacts on read-
and maintainability, make it harder for the compiler to optimize your
programs, and might even have a negative impact on the efficiency of
your program. And even if you're lucky and do not face these negative
consequences, you will spend your time on optimizing of code with
minimal effects, which obviously isn't too efficient either. For
example, most of the time there is no point in optimizing code that
parses and validates your configuration files, as these things are
usually only done on program startup.
Performance optimization is a fine art that profits from experience, the
more the better, and there are no standard recipes anyone can rely on.
Sorry for that, I know that is not what you wanted. Instead, the most
valuable tool for performance optimization is between your ears, so
learn about the different data types and the algorithms you needs, then
build your program so that it does what it's supposed to, then measure
(profile) its characteristics at runtime, and then use your brains not
only to first identify the places where optimization is efficient and
second think about the inner workings of these places and what you can
do to improve them. Good luck and have fun!
von Rbx (rcx)
Neben netten Zitaten und Allgemeinplätzen zum Thema sollte man aber
schon von einigen Stichworten gehört haben:
- https://agner.org
- Allignment
- Register-Renaming
- Registerabhängigkeiten
- Sprungvorhersage
- Effizienz, bzw. effiziente Algorithmen
(https://de.wikipedia.org/wiki/Effizienz_(Informatik))
- Rundungsfehler
- Worst Pessimum
- Lernen durch Üben
- Üben, Üben, Üben
- Übung macht den Meister
..oder auch:
https://stackoverflow.blog/2020/07/08/improving-performance-with-simd-intrinsics-in-three-use-cases/
- https://www.boost.org
- https://dlang.org
..und wird feststellen müssen, dass einiges nur deswegen an C++ bindet,
weil C++ einigermaßen hardewarefreundlich wie auch stark
erfahrungsabhängig oder auch verbreitet ist.
Despite the TO seemed to look for this sort of standard recipes (and,
well... "Allgemeinplätzchen") you mention, exactly that was what I
wanted to avoid. I've seen far too many developers who follow such
recipes whenever possible, no matter if suitable. In the end their code
gets hard to maintain and might even restrain the compiler's optimizer.
Edit: missing space added.
von Rbx (rcx)
> wanted to avoid.
Die Textmauer da oben muss ja auch irgendwie gefiltert werden, und in
Referenz gesetzt werden, und so steht halt etwas konkreteres da drunter.
Ist auch klar, die Dummen sind natürlich immer die anderen. Was soll man
von Leuten halten, die das Forum schon lange nutzen, aber trotzdem
(immer noch) nicht in der Lage sind, auf die Schnelle brauchbares
Bildmaterial auf eine Frage zu liefern?
I don't think so, and even if, ...
...you think contextless catchwords are "etwas konkretes"?
Oh, I see, you don't want to help the TO, but just contradict me.
Otherwise you would have used the TO's language. Thank you.
von Rbx (rcx)
Wieso. Es wurde in ein deutschsprachiges Forum gepostet. Man stelle sich
mal den umgekehrten Fall vor: Ich poste eine Frage bei
https://stackoverflow.com auf Deutsch.
Die Logik funktioniert generell in beide Richtungen. So gesehen bist du
nicht gut in Logik wenn du aufgrund des Spracheinsatzes oder von
relativen Beitragsergänzungen auf Hilfsverweigerung schließt.
I see. You do not only piss me off, but also patronize the TO.
Ich antworte hier auch immer in Deutsch. Wieso erwarten alle immer von
uns, dass wir als Minimum Englisch antworten?
Kann doch die Seite auf Englisch übersetzen.
Davon ab, auch wenn ich es gut verstehe, ich bin über 40 Jahre aus der
Schule und schreibe selten bis nie Englisch.
Soll froh sein, dass er überhaupt eine Antwort bekommt.
Du tust gerade so, als gebe es einen Zwang, hier zu antworten. Aber wer
kein Englisch kann, zu eingerostet oder zu faul dazu ist, muß das gar
nicht.
In einem Forum, das sich mit Mikrocontrollern und Technik beschäftigt?
Davon abgesehen zeigt sich daran natürlich recht eindeutig, wer anderen
helfen will und wer nur zum Stänkern hier ist.
Sprich in England oder in Amerika deutsch. Sprechen die dann automatisch
deutsch mit dir?
Und, natürlich kann man auch was zum Thema schreiben.
Wenn jemand Hilfe annehmen will, dann wird er doch wohl in der Lage sein
den Text zu übersetzen.
> deutsch mit dir?
Spreche bei mir um die Ecke (in Deutschland) in einem beliebigen Laden
Arabisch. Antworten die dann auf Arabisch? Ja!
von Bradward B. (Firma: Starfleet) (ltjg_boimler)
This is not specific to any programming language, so there is no
specific recommendation other than studying mathematics, particularly
numerical analysis.
See also: Niklaus Wirth: "Algorithmen und Datenstrukturen" (ISBN:
ISBN-13
978-3519022503)
And also remember Amdahl's law .
Beitrag #7668563 wurde von einem Moderator gelöscht.
Da es vom Forenbetreiber auch ein englischsprachiges Forum gibt, und die
Haussprache hier halt eben nicht englisch ist, gehört es sich nicht,
hier ausschweifende Diskussionen auf Englisch zu führen.
Es mag den einen oder anderen überraschen, aber in diesem Forum sind
auch Leute unterwegs, die Ahnung von Dingen haben und trotzdem keine
oder nur sehr schlechte Englischkenntnisse haben.
(Zwischen Englischkenntnissen und Fachkompetenz besteht keine
Korrelation)
Letztlich geht es um Umgangsformen. Genausowenig, wie man in
deutschsprachigen Internetforen plenkt, genausowenig sollte man dort
ohne Not mit einer Fremdsprache ankommen.
Hier Deutsch zu schreiben ist eine Bringschuld, bei der die Verwendung
von Onlineübersetzern seitens der nicht des Deutschen mächtigen durchaus
erwartet werden kann. Deepl.com und seit einiger Zeit auch
translate.google.com liefern brauchbare Ergebnisse.
For those inept to communicate in german: please use an online
translation service such as deepl.com or translate.google.com. This
forum is a german-speaking forum, and posting in other languages is
considered somewhat rude if not offensive.
And not everyone here who's on a helpful mission is abled to answer in
decent and sufficient non-ambiguous english.
Love it or leave it or just ignore it ...
Nee, Jüngelchen, so funktioniert das hier nicht.
Und warum empfiehlst Du jemandem auf Englisch ein deutschsprachiges
Buch? Das ist auch ein bisschen widersprüchlich, meinst Du nicht auch?
> deutsch mit dir?
Naja, in Pennsylvania versuchen einige Natives es immerhin. Auch an Unis
kann man schonmal auf Leute treffen, die keine gebürtigen Deutschen
sind, aber trotzdem recht gut Deutsch sprechen (und das auch wollen).
Aber klar: Selbst bei meinem (leider recht lausigen) Englisch wird das
Mittel der Wahl i.d.R. Englisch sein. Ausnahme ist natürlich, wenn man
auf einen Deutschen trifft, der aus dem einen oder anderen Grund im
englischsprachigen Ausland werkelt. Aber selbst dann ist es fast immer
so, dass man zugunsten der anderen am Gespräch beteiligten nach ein,
zwei freundlichen Sätzen wieder auf Englisch umschaltet.
...and obviously there are a lot of childish people around here.
True that. And then, if i remember correctly, there was a time when the
postings from embdev.net have also been posted here. In English, oh my
god.
> god.
Tja, seitdem viele erkannt haben, dass dieses Feature von einigen
(genaue interne Bezeichnung zensiert) Deutschen missbräuchlich genutzt
wurde, hat sich das zum Glück weitgehend erledigt.
Aber irgendein grenzdebiler Honk probiert's halt immer mal wieder, damit
durchzukommen...
Ein T. schrieb im Beitrag #7668563:
> Some words are the same in both languages. Idiot and Kindergarten for
> exampl
Kindergarten wusste ich nicht.
Aber ich kann dir gerne zeigen was rechts und links heißt.
Sag mal wo du wohnst!
Was ich damit sagen wollte, dass bei uns erwartet wird, dass wir
selbstverständlich in der Sprache des anderen oder alternativ immer
Englisch sprechen, wenn wir mit Fremden zu tun haben. Leider erwarten
wir, was auch nicht richtig ist und ich unbedingt für mich ändern muss,
dass die Holländer immer deutsch mit uns sprechen. Ich verstehe die
recht gut, aber sprechen, na ja.
Wie hier schon geschrieben wurde, es gibt auch das µC.net in Englisch.
Heute hatte ich noch mit China zu tun. Selbstverständlich schreibe ich
dann auch in Englisch.
Aber hier ist nun mal ein deutsches Forum. Die einzige Ausnahme, der
TT-Thread, da kann man schon mal in Englisch schreiben, weil der wohl
ziemlich international ist.
Eigentlich könnte man den Startbeitrag schon als Affront ansehen.
Schreib doch mal in einem Englischen Forum einen Beitrag in Deutsch und
erwarte, dass dir alle in Deutsch antworten.
Aber was ist so schlimm daran, wenn man in Deutsch antwortet? Hauptsache
ist doch, dass geholfen wird.
Nope, die Reichweite erstreckt sich mindestens auf D-A-CH und spätestens
bei CH sind etliche dabei, für die Hochdeutsch eine ausgemachte
Fremdsprache ist.
Was man als Affront ansieht und was nicht ist doch eine sehr
individuelle Einschätzung, die auch stark von den persönlichen
Fähigkeiten abhängig ist.
So wird ein Einbeiniger auf die Auforderung zum gemeinsamen Lauf eher
vergnatzt reagieren. Oder der Abstinzler die Aufforderung zum
Gehaltvollen Umtrunk. Andere sehen Anfragen als Affront an, die der TO
mit minimalen google-Aufwand selbst lösen könnte ...
BTW: Ist jetzt die Verwendung von Funk-Kürzeln wie Q-Gruppen etc. ein
Affront für die "Unwissenden" ??
73
Конец передачи
> ist doch eine sehr
Da hast du recht.
Wie auch immer. Ich beende, zumindest für mich, die Diskussion darüber.
>> exampl
LOL!
