1 | /*
2 | *
3 | * Program for a door watch with sleep mode and pin change interrupt wake up
4 | * 2024
5 | *
6 | */
7 |
8 |
9 | #include <stdint.h> // Integer variable
10 | #include <avr/io.h> // I/O ports
11 | #include <util/delay.h> // Delay function
12 | #include <avr/sleep.h> // Sleep mode
13 | #include <avr/interrupt.h> // Interrupt implemention
14 | #include <avr/wdt.h> // Watchdog timer
15 |
16 | #ifndef F_CPU // Include guards
17 | #define F_CPU 8000000UL // AT90USB162 runs at 8 MHz clock speed - unsigned long
18 | #endif // Include guards
19 |
20 |
21 | /***************************************************
22 | * Name: ISR(PCINT0_vect)
23 | *
24 | * Returns: Nothing.
25 | *
26 | * Parameters: None.
27 | *
28 | * Description: Interrupt service routine
29 | *
30 | ***************************************************/
31 | ISR(PCINT0_vect){ // Port B, PCINT0 - PCINT7
32 | }
33 |
34 |
35 | /***************************************************
36 | * Name: status
37 | *
38 | * Returns: Nothing.
39 | *
40 | * Parameters: None.
41 | *
42 | * Description: Status indication.
43 | *
44 | ***************************************************/
45 | void status (){
46 | PORTB |= (1 << PB5);
47 | _delay_ms (1000);
48 | PORTB &= ~(1 << PB5);
49 | _delay_ms (1000);
50 | }
51 |
52 |
53 | /***************************************************
54 | * Name: open
55 | *
56 | * Returns: Nothing.
57 | *
58 | * Parameters: None.
59 | *
60 | * Description: Indication for door is open.
61 | *
62 | ***************************************************/
63 | void open (){
64 | PORTB |= (1 << PB6);
65 | _delay_ms (1000);
66 | PORTB &= ~(1 << PB6);
67 | _delay_ms (1000);
68 | }
69 |
70 |
71 | /***************************************************
72 | * Name: alarm
73 | *
74 | * Returns: Nothing.
75 | *
76 | * Parameters: None.
77 | *
78 | * Description: Alarm.
79 | *
80 | ***************************************************/
81 | void alarm (){
82 | PORTB |= (1 << PB5);
83 | PORTB |= (1 << PB6);
84 | _delay_ms (1000);
85 | PORTB &= ~(1 << PB5);
86 | PORTB &= ~(1 << PB6);
87 | _delay_ms (1000);
88 | }
89 |
90 |
91 | /***************************************************
92 | * Name: main(void)
93 | *
94 | * Returns: Nothing.
95 | *
96 | * Parameters: None.
97 | *
98 | * Description: Main program
99 | *
100 | ***************************************************/
101 | int main(void){
102 |
103 | // I/O Pin setup
104 | DDRB &= ~(1 << PB4); // Pin PB4 as input - Button
105 | DDRB |= (1 << PB5); // Pin PB5 as output - green LED
106 | DDRB |= (1 << PB6); // Pin PB6 as output - Buzzer/ red LED
107 |
108 | // Variables
109 | uint8_t counter = 0; // Variable for counting the clock cycles how long the door was open
110 |
111 | // Main loop
112 | while (1){
113 |
114 | status(); // Status blink
115 |
116 | if (PINB & (1 << PB4) && (counter < 2)){ // If button PB4 pressed = door open (HIGH -> LOW)
117 | for (uint8_t i = 0; i <= 2; i++){ // Loop until it checks input again (2 times)
118 | open(); // Door open indication
119 | }
120 | counter += 1; // Counts up for how many times is input "door open" checked
121 | }
122 |
123 | if (PINB & (1 << PB4) && (counter == 2)){ // If button PB4 still pressed = door still open (HIGH -> LOW)
124 | for (uint8_t i = 0; i <= 2; i++){ // Loop until it checks input again (2 times)
125 | alarm(); // Door to long open -> alarm
126 | }
127 | }
128 |
129 | if ((!(PINB & (1 << PB4))) && (counter <= 2)){ // If button PB4 released = door closed and wasn't open before or closed for a while (LOW -> HIGH)
130 | counter = 0; // Reset counter
131 |
132 | // Pin change interrupt setup
133 | cli(); // Disable interrupt for programming
134 | PCICR |= (1<<PCIE0); // Turn on port b
135 | PCMSK0 |= (1 << PB4); // Turn on pin PB4, which is PCINT4
136 | sei(); // Enable interrupt
137 |
138 | // Sleep mode list
139 | set_sleep_mode(SLEEP_MODE_PWR_DOWN);
140 | // set_sleep_mode(SLEEP_MODE_PWR_SAVE);
141 | // set_sleep_mode(SLEEP_MODE_STANDBY);
142 | // set_sleep_mode(SLEEP_MODE_EXT_STANDBY);
143 | // set_sleep_mode(SLEEP_MODE_IDLE);
144 | // set_sleep_mode(SLEEP_MODE_ADC);
145 |
146 | sleep_mode(); // Start sleep mode
147 | }
148 | }
149 | }
