Forum: FPGA, VHDL & Verilog Assertion Error in $RTOI Verilog function
von Cainã (cainao)
I'm creating a combinational multiplier and I wrote it in Verilog, but
I'm having an unusual error. My simulation tool runs the code ok with
testbench, but the logic synthesis tool shows the error "Internal
assertion failure. (VER-37)". I tested and the error is found on line
23, specifically in the $RTOI function, but I didn't find a way to fix
it. I'm usign Synopsis tools.
All i want is get the rounded square of a number and use it to build my
index.
von Vancouver (vancouver)
Internal errors usually mean that there is really a bug in the synthesis
tool. Can you try another tool, like Vivado? I don't understand the
details of your code, but there is no reason why $rtoi() should fail
here.
Instead of $rtoi() you could use a simple integer casting just to see if
that passes the synthesis. And then you could write your own version of
$rtoi() and file a ticket at Synopsys.
