1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 | use IEEE.NUMERIC_STD.ALL;
4 |
5 | entity LB_src is
6 | -- generic (NUM_LB : integer := 4 );
7 | Port ( clk, i_lVal, i_fVal, n_rst : in std_logic;
8 | i_data : in std_logic_vector(7 downto 0);
9 |
10 | o_lVal, o_fVal : out std_logic;
11 | -- o_data : out std_logic_vector(8*(NUM_LB+1)-1 downto 0) );
12 | o_data : out std_logic_vector(39 downto 0) );
13 | end LB_src;
14 |
15 | architecture Behavioral of LB_src is
16 |
17 | ---- Konstanten
18 | constant NUM_LB : integer := 4;
19 | constant ONES_VEC : std_logic_vector(NUM_LB-1 downto 0) := (others => '1');
20 |
21 | ---- Komponenten
22 | component LB_Fifo
23 | PORT (
24 | clk : IN STD_LOGIC;
25 | srst : IN STD_LOGIC;
26 | din : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
27 | wr_en : IN STD_LOGIC;
28 | rd_en : IN STD_LOGIC;
29 | dout : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
30 | full : OUT STD_LOGIC;
31 | empty : OUT STD_LOGIC
32 | );
33 | end component;
34 |
35 | ---- Signale
36 | signal LB_data, LB_data_del, LB_data_del_del : std_logic_vector(i_data'length*(NUM_LB+1) -1 downto 0) := (others => '0');
37 | signal dout_f1, dout_f2, dout_f3, dout_f4 : std_logic_vector(i_data'range) := (others => '0');
38 | signal i_data_sig, i_data_sig_del : std_logic_vector(i_data'range) := (others => '0');
39 |
40 | signal f_full_REG, f_empty_REG, f_empty_REG_del, f_wr_REG, f_rd_REG, mask_wr, mask_rd : std_logic_vector(NUM_LB-1 downto 0) := (others => '0');
41 | signal lVal_REG, fVal_REG : std_logic_vector(NUM_LB downto 0) := (others => '0');
42 | signal last_line_cnt : unsigned(NUM_LB downto 0) := (others => '0');
43 |
44 | signal lVal_sig, fVal_sig, r_edge_lVal, f_edge_lVal, r_edge_fVal, f_edge_fVal : std_logic := '0';
45 |
46 | signal ONES_WITH_ZERO_VEC : std_logic_vector(NUM_LB-1 downto 0) := (others => '1');
47 |
48 | begin
49 |
50 | -- Fifo Instanziierung
51 | Fifo0 : LB_Fifo
52 | port map(clk => clk, srst => (not n_rst), din => i_data_sig, wr_en => f_wr_REG(0),
53 | rd_en => f_rd_REG(0), dout => dout_f1, full => f_full_REG(0), empty => f_empty_REG(0));
54 |
55 | Fifo1 : LB_Fifo
56 | port map(clk => clk, srst => (not n_rst), din => dout_f1, wr_en => f_wr_REG(1),
57 | rd_en => f_rd_REG(1), dout => dout_f2, full => f_full_REG(1), empty => f_empty_REG(1));
58 |
59 | Fifo2 : LB_Fifo
60 | port map(clk => clk, srst => (not n_rst), din => dout_f2, wr_en => f_wr_REG(2),
61 | rd_en => f_rd_REG(2), dout => dout_f3, full => f_full_REG(2), empty => f_empty_REG(2));
62 |
63 | Fifo3 : LB_Fifo
64 | port map(clk => clk, srst => (not n_rst), din => dout_f3, wr_en => f_wr_REG(3),
65 | rd_en => f_rd_REG(3), dout => dout_f4, full => f_full_REG(3), empty => f_empty_REG(3));
66 |
67 | ONES_WITH_ZERO_VEC(0) <= '0';
68 |
69 | o_data <= LB_data;
70 | LB_data <= dout_f4 & dout_f3 & dout_f2 & dout_f1 & i_data_sig_del;
71 |
72 | r_edge_lVal <= i_lVal AND (NOT lVal_sig);
73 | f_edge_lVal <= (NOT i_lVal) AND lVal_sig;
74 |
75 | f_edge_fVal <= (NOT i_fVal) AND fVal_sig;
76 |
77 | CONTROLL_FIFOS: process(clk) begin
78 | if rising_edge(clk) then
79 | if n_rst = '0' then
80 | lVal_REG <= (others => '0');
81 | fVal_REG <= (others => '0');
82 |
83 | o_lVal <= '0';
84 | o_fVal <= '0';
85 |
86 | mask_wr(mask_wr'left downto 1) <= (others => '0');
87 | mask_rd(mask_rd'left downto 1) <= (others => '0');
88 | mask_wr(0) <= '1';
89 |
90 | last_line_cnt <= (others => '0');
91 |
92 | else
93 | i_data_sig <= i_data;
94 | i_data_sig_del <= i_data_sig;
95 |
96 | f_empty_REG_del <= f_empty_REG;
97 | lVal_sig <= i_lVal;
98 | fVal_sig <= i_fVal;
99 |
100 |
101 | if r_edge_lVal = '1' and i_fVal = '1' then
102 | f_wr_REG(0) <= '1';
103 | f_rd_REG <= mask_rd(mask_rd'left downto 0);
104 |
105 | fVal_REG <= fVal_REG(fVal_REG'left-1 downto 0) & '1';
106 | lVal_REG <= lVal_REG(lVal_REG'left-1 downto 0) & '1';
107 |
108 | -- i_lVal ist mindestens für einen Takt auf '1'-Pegel
109 | elsif i_lVal = '1' and i_fVal = '1' then
110 | o_lVal <= lVal_REG(lVal_REG'left);
111 | o_fVal <= fVal_REG(fVal_REG'left);
112 | f_wr_REG <= mask_wr;
113 | end if;
114 |
115 | -- fallende Flanke i_lVal
116 | if f_edge_lVal = '1' and i_fVal = '1' then
117 | f_rd_REG <= (others => '0');
118 | f_wr_REG(0) <= '0';
119 |
120 | mask_wr <= mask_wr(mask_wr'left-1 downto 0) & '1' ;
121 | mask_rd <= mask_rd(mask_rd'left-1 downto 0) & '1' ;
122 |
123 | -- i_lVal ist mindestens einen Takt auf '0'-Pegel
124 | elsif i_lVal = '0' and i_fVal = '1' then
125 | o_lVal <= '0';
126 |
127 | f_rd_REG <= (others => '0');
128 | f_wr_REG <= (others => '0');
129 | end if;
130 |
131 | -- fallende Flanke i_fVal -> Frame ist vorbei
132 | if f_edge_fVal = '1' then
133 | last_line_cnt <= last_line_cnt + 1;
134 | f_rd_REG <= (others => '0');
135 | f_wr_REG(0) <= '0';
136 | mask_wr <= mask_wr(mask_wr'left-1 downto 0) & '0';
137 |
138 | -- Letzte Zeilen -> d.H. Fifos nacheinander leer lesen
139 | elsif f_edge_fVal = '0' and i_fVal = '0' and unsigned(f_empty_REG) = 0 then
140 | f_rd_REG <= mask_rd(mask_rd'left downto 0);
141 | f_wr_REG <= (others => '0');
142 | o_lVal <= '0';
143 | end if;
144 |
145 | -- last_line_cnt = 1 -> Aufhören in Fifo zu schreiben, o_lVal ein Takt ausschalten und last_line_cnt hochzählen
146 | if last_line_cnt = 1 then
147 | f_wr_REG <= (others => '0');
148 |
149 | o_lVal <= '0';
150 | last_line_cnt <= last_line_cnt + 1;
151 |
152 | -- last_line_cnt = 2 -> o_lVal wieder einschalten, Letzte Zeilen aus Fifos raus-lesen bzw. rein-schreiben
153 | elsif last_line_cnt = 2 then
154 | o_lVal <= lVal_REG(lVal_REG'left);
155 | f_wr_REG <= mask_wr;
156 | f_rd_REG <= mask_rd(mask_rd'left downto 0);
157 | end if;
158 |
159 | -- Das Erste / Ein weiteres Fifo ist leer.
160 | if f_empty_REG /= f_empty_REG_del and last_line_cnt = 2 then
161 |
162 | mask_rd <= mask_rd(mask_rd'left-1 downto 0) & '0';
163 | mask_wr <= mask_wr(mask_wr'left-1 downto 0) & '0';
164 |
165 | f_rd_REG <= (others => '0');
166 | f_wr_REG <= (others => '0');
167 |
168 | o_lVal <= '0';
169 |
170 | -- Alles Fifos sind leer
171 | if f_empty_REG = ONES_VEC then
172 | o_fVal <= '0';
173 |
174 | mask_wr(0) <= '1';
175 | mask_rd <= (others => '0');
176 |
177 | lVal_REG <= (others => '0');
178 | fVal_REG <= (others => '0');
179 | last_line_cnt <= (others => '0');
180 | end if;
181 | end if;
182 | end if;
183 | end if;
184 | end process CONTROLL_FIFOS;
185 |
186 | end Behavioral;
