Forum: µC & Digital Electronics How To Flash NOR-Flash MX25U128 From MXIC
von Andreas B. (a_ndreas)
Hello Forum
long story short, yesterday i bricked my Mini-PC while flashing the
BIOS. Now I have learned that an MXIC (MX25U12873F) 1.8V, 128M-BIT [x
1/x 2/x 4] CMOS MXSMIO  (SERIAL MULTI I/O) FLASH MEMORY is used to store
the BIOS.
I cant find any valuable information on how to flash the IC -the right-
way. The IC is an 8-pin SOP soldered on board. I have the image file but
no clue to flash the IC.
I whish to reprogram the IC using the BIOS image provided, in hopes to
revive the mini-pc.
The manufacturers data-sheet can be found here:
https://www.mxic.com.tw/en-us/products/NOR-Flash/Serial-NOR-Flash/Pages/spec.aspx?p=MX25U12873F&m=Serial%20NOR%20Flash&n=PM2348#Technical-Documents
I tried hard on ebay and amazon to find a suitable Serial EEPROM & FLASH
PROGRAMMER for this specific IC from MXIC but im not sure which
programmer is to pick.
any help appreciated
thanks in advance
Andreas
von A. B. (Guest)
That's a rather standard SPI flash, so almost all programmers available
for SPI flash devices will do - except it's 1.8V only, so you have to
look for a programmer supporting that supply level.
Another option is to get a Nucleo-Board with 1.8V option like
Nucleo-H7A3ZI-Q, -H723ZG, -H743ZI2, jumper it to VDD 1.8V and use to use
OpenOCD with QSPI driver (built in on recent versions) or with patch
https://review.openocd.org/c/openocd/+/4760.
The main obstacle in both cases is to remove the chip from the
mainboard, attach it to the programmer (by a test socket) and later
solder it to the mainboard again. That's not trivial if you don't have
some experience in (de-) soldering. To program it on the mainboard is
possible theoretically but requires some precautions (keeping the
mainboard's connections in high-impedance state etc.)
So, it boild downs to this rather mechanical issue ... Do you have any
experience regarding that? If not, the question regarding a programmer
is rather pointless, I'm afraid.
von john mil's (Guest)
i having problems with my motherboard. it runs very slow. and i try to
update it. i use bios flash. and it installs corectly.. sadenly.. arter
the restart my board wont display anymore... what im ganna do?? my
motherboad is A320M PRO-VH PLUS.. MY PROCESSOR IS AMD A6 9500 series..
its no use anymore.
