Forum: µC & Digital Electronics ESP32+WLED / no LED control
von Stev (Guest)
Hello, everyone,
even if there is already a similar thread here
(Beitrag "ESP32 welche Einstellungen in WLED?"), I actually have pretty
much the same problem and can't get it solved.
I have an AZ-Delivery ESP32 Dev Kit C V2 ESP32-WROOM-32, plus WS2815 LED
strips 5m from BTF-Lighting, as well as an ext. power supply on 12VDC
(20A).
Flashing the ESP32 with the current WLED version (including the current
WLED Sound reactive version) worked great. The web interface and app
access work.
However, my LEDs do more or less what they want. As soon as the Data PIN
is connected, the LEDs flash colorfully. They do everything, just not
what I specify in the app or via the web interface. Something seems to
work ..... if I set 20 LEDs in the settings, only about 20 LEDs come on
(flashing). If I set more, more LEDs will flash. But none of them do
what they should. Do you have a tip for me as to what I'm doing wrong?
Is the board possibly not supported?
As already described, the 12VDC is provided by an external power supply
unit.
I tested different GPIOs ... always the same problem.
Example: Connection of DataIN to pin G2 with the following settings in
the WLED:
Total LED count: 20
2D matrix: 1x20
LED voltage (Max.current for a single LED): WS2815 (12mA)
LED outputs: WS281x
Color Order: RGB
Pin: 2
Start: 0
Count: 20
Do any of you still have an idea?
Thanks in advance.
VG Stev
