Forum: Analog Circuits transformer for ECC83 plate voltage
von Valentin (Guest)
I'm searching for a transformer that has a ratio of 1:1 for creating a
supply for two ECC83 tubes. I can't seem to find one that can be print
mounted to a PCB.
As an alternative I thought about cascading two normal transformers, for
example 230/24V straight into 24/230V. Would this also work? I don't
want a custom transformer to be made, I would prefer off the shelf
components.
Thanks in advance!
Valentin
von matzetronics (Guest)
You can mount two small transformers back to back, but the smaller they
are, the smaller is the ratio when used in reverse.
E.g. a 4VA print transformer with 220V/12V will not yield 220V when fed
with 12V, it wil be more in the range of 150V. Keep this in mind. The
4VA transformer will more likely give 220V on its output when supplied
with 18-20V.
This ratio will increase with larger transformers.
von Nils (Guest)
Maybe this little transformer here will do the job? It's not 1:1 but
close to it. In addition you'll also get a 6.3 winding for two ECC83
tubes:
https://www.tube-town.net/ttstore/tt-powertrafo-ei-230-200-6-3-7-va.html
Thanks for the answers so far. I've had another idea this morning. Would
it work when I use it as I've drawn it in the photo I attached? I am
needing a symmetrical +-15V anyway for my project, so I was thinking
about using two transformers each with two 115V primary windings. Are
there any issues I'm facing when connecting it that way? I am only
guessing I have to use transformers with double the rated power because
I would be only driving one of the primary windings, the other one would
be used to form a secondary for the tube plate voltage (HV)
-Valou
von Nils (Guest)
I doubt it is a good idea to abuse one half of the primary windings to
get your HV supply. The transformer has a guaranteed insulation between
primary and secondaries. This is not the case for the two primaries.
If you get a short between the primary windings you might end up having
mains voltage without galvanic insulation on your HV supply.
In theory it would work though.
von Karadur (Guest)
If you have different loads at the transformers the primary
voltages/currents are not equal.
@Nils, I was suspecting the same thing already...
Plus the loads not being equal is indeed a real concern here.
I have to think this through again, thanks for the answers so far!
-Valentin
von https://www.bag37.com/category-930_769.html (Guest)
問い合わせにも大変丁寧に応対していただき、非常に品質のよい商品を、購入させていただきました。
梱包も丁寧で、新品を買ったのと同じ気分です。
信頼できるショップさんだと思います。
シャネルバッグ購入。
von Angelahelen A. (Company: Angelahelen) (angelahelen)
Your information are very useful me and need more information about
this.
https://jealouscomputers.com/7-best-ways-to-cool-the-laptop-while-gaming/
von LiamOliver1 L. (Company: LiamOliver1) (liamoliver1)
Any one suggested me how to build pc and PC gaming in computer and i
also suggested you to visit here.
https://technoburst.com/best-motherboards-for-ryzen-9-5900x/
von https://www.kopiok.com/product/detail-5193.html (Guest)
2021激安通販専門店
ロレックス、ブルガリ、フランク ミュラー、
オーデマ ピゲ、ブライトリング、グッチ、エルメス、パネライ、
当店のスーパーコピー商品は他店よりも質が高く、
金額も安くなっております。
ご購入する度、ご安心とご満足の届けることを旨にしております
スーパーコピー 韓国 通販  オットー https://www.kopiok.com/product/detail-5193.html
