Forum: Analog Circuits Thyristor as DC switch - resitance to high
von Hans L. (haled)
Hi everyone,
I am currently  building a remote controlled switch that is cutting the
power line of a device. The problem hereby is that I have no access to
ground so the switch needs to be powered by the very same cable it is
cutting/switching.
Until now I managed to make this "two-wire-solution" work with a MCU and
a thyristor as you can see in the picture. Hereby when the power supply
is activated the current flows trough the MCU as the thyristor is still
high-resistance. Once the MCU triggers the thyristor it becomes
low-resistance so the switch is "ON". At the same time the MCU turns off
as it only gets low voltage which is ok as the Tyristor stays in
conductive mode as long as current flow is high enough. The system gets
reset by cutting the power supply which is exactly the behavior I want
to accomplish.
My problem is, that the thyristor has a relatively high resistance in
conductive mode and I don't know how to find a thyristor with minimum
resistance and what this minimum value would be.
Maybe there is also an option to use a relay and have the same
functionality as with the thyristor? Ideally the switch would work for
low and higher current devices up to 15 ampere. The power supply is 12V.
I hope I could describe my problem relatively clear.
Thanks a lot :-)
von A-Freak (Guest)
Unfortunately, a thyristor has always at least about 1,2V drop across
two forward bieased PN junctions.
The only idea i could think about that has much lower voltage drop would
be a kind of latching relay that has a very low resistance coil in
series with the load, some kind of mechanical thyristor.
