Forum: FPGA, VHDL & Verilog How to generate Trigger for 500ns in Verilog ?
von Saraswathy S. (saras015)
I am working with FPGA board. For my test, i am going to add the trigger
logic in one side [One PC], and in other side the counter design will be
added in XILIXN VIVADO and should start to give its counter after
receiving the trigger signal.
For every trigger [500ns], the counter should start. To execute this
task, i need the verilog code for Creating the Trigger Signal.
module counter(
    input clk,
    input reset,
    output [127:0] counter_out,
    output trig
    reg trig=0;
    reg [127:0] counter_out=0;
    reg [7:0] temp=0;
    always@(posedge clk)
    begin
    if(~reset)
        begin
        trig<=0;
        counter_out<=0;
        end
    else
        begin
        counter_out<=counter_out+1;
        temp<=temp+1;
        if(temp==25)
            begin
            temp<=0;
            trig<=~trig;
            end
        end
    end
30
endmodule
: Edited by Moderator
