Forum: DSP What is the effect of reducing nfft less than the signal length
von Usman A. (Company: LUMS) (usmanashraf678)
Dear members,
I am analyzing a signal in matlab by taking its fft. The singal has 200
samples and I am currently taking nfft = 256. I understand that this
would result in zero padding. Now, I want to try to reduce the nfft to
128, 64 etc. I wanted to ask what should I expect to happen with the
fft.
Matlab says
for Y = fft(X,n)
If X is a vector and the length of X is greater than n, then X is
truncated to length n. What would this actually result in? Can anyone
explain, please?
Thanks in advance.
von Andreas S. (andreas) (Admin)
You will get a reduced frequency resolution, and, depending on your
input vector, windowing artifacts (you can consider truncation as
equivalent to applying a rectangular window).
von Martin B. (Guest)
You may also use Nfft = 200
I think in matlab you can use any number Nfft which is a factor of
2,3,5.
It is not neccesary to use Nfft = 2^n, You may also use
Nfft=200=2*2*2*5*5
Most fft librraries are able to use these numbers of Nfft (fftw, kissFFT
