Forum: FPGA, VHDL & Verilog executing optical sensors with vhdl
Author: Kobi (Guest)
Hello everybody, and thank you for having me here with you.
i'm having troubles executing this optical sensor module that i created
physically using VHDL in collaboration with DE-2/115
the pic i added should explain what i am trying to do... i want to be
able to make this work by pressing one of the buttons on my board which
cause a LED to light
this is the code i've written so far:
and for some reason it's not working :/
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
entity mouse_lab IS
port(reset,clock_in: in STD_LOGIC;
IF2: IN STD_LOGIC;
LED1: OUT STD_LOGIC);
END mouse_lab;
architecture behave OF mouse_lab IS
BEGIN
PROCESS (clock_in,IF2)
BEGIN
if reset = '0' then
led1 <='1';
else
IF clock_in'event and clock_in = '1' then
if IF2 = '0' then
led1 <='0';
else
led1 <='1';
end if;
end if;
end if;
END process;
END behave;
Author: Klakx (Guest)
The sensitivity List should have reset instead of IF2.
How is your Testbench working. Also people often wrongly apply clock to
wrong Pin
  • [vhdl]VHDL code[/vhdl]
