Forum: FPGA, VHDL & Verilog Help with the RTC-8564 in ZC702 evaluation board of xilinx
von flote (Guest)
Hello people,
I am trying to run this Real Time Clock module but I am not lucky. I
have been using like starting point the xiicps_eeprom_polled_example.c
provided by xilinx in the folder "drivers" of the installation path. I
did some modifications to adpat this code to the RTC and I have trying
to send just an address+data byte to the RTC using the function
"XIicPs_MasterSendPolled". However I am only able to see that the
Address is sent correctly, however the data byte is not sent. (See the
code attached)
Some considerations:
- I want to connect to the RTC through a SDK standalone project.
- The switch is working properly because the oscilloscope pictures
attached were taken directly in the I2C pins of the RTC-8564. I soldered
two cables direcly on the chip to check if the signals were driven to
the chip.
Regards,
Enrique Perez
von Enrique P. (flote21)
I forgot to attach te file...
Problem solved. Wrong address...
