Forum: AVB Controller entity ID
Author: RICHARD FOSS (Company: Rhodes University) (richardfoss)
If I am writing a controller application, how do I create the controller
GUID that goes into the controller entity ID field of, for example a
Thanks for any help with this!
Author: Andre Labelle (andrelabelle)
IEEE Std 1722.1-2013 just says it should be unique. It makes sense to
use a host interface MAC-48 and append a random number to make up 64
Author: Richard Foss (Guest)
Hi Andre,
Thanks for the post and apologies for the slow reply. I had previously
received an answer from Jeff Koftinoff, which confirmed what you
indicated. I think it would be helpful to quote Jeff, and I don't think
he would mind:
"The controller is an entity. The same rules apply for the entity as
others; specifically, it needs to be unique on the network, it needs to
be prefixed by a IEEE assigned OUI  MA-L  MA-M or MA-S
Typically, people find the “Primary MAC address” of the computer that
the controller is running on.
This is a six byte value: UU:VV:WW:XX:YY:ZZ.
You then convert this to an EUI-64 in the way IEEE specifies:
And this would then be the controller’s Entity ID (GUID is an old term
which has different definitions)
If you need more than one controller per computer, then you would
replace the middle FF:FE with two byte values so that each controller
running on the computer would get a unique ID."
My AVDECC messages are working fine with this approach.
