Forum: µC & Digital Electronics Help me with my code
Author: John Welo (Company: Welcomn) (librali)
Greetings ,
I have to do a program code in PIC ASSEMBLY LANGUAGE using MPLAB and
after that do simulation using PROTEUS . The program that should I write
is to :
Toggle the LEDs every half second in sequence: green, yellow, red,
green,...
Count cycles to obtain timing.
Use 4 MHz crystal for 1 microsecond internal clock period.
USING timer0 INT .
Here is what I did :
here is my code that I did but contain some errors :
list p=16F877a
#include <p16f877A.inc>
w_temp
STATUS_temp
endc
push macro
movwf w_temp
swapf STATUS,w
movwf STATUS_temp
endm
pop macro
swapf STATUS_temp,w
movwf STATUS
swapf w_temp,f
swapf w_temp,w
endm
org 0X00
goto start
org 0X04
goto Interkey
org 0X05
start
banksel TRISD
clrf TRISD
banksel ADCON1
movlw 0X06
movwf ADCON1
movlw 0X90
movwf INTCON
banksel OPTION_REG
bsf OPTION_REG,6
l nop
goto l
Interkey
banksel PORTA
movf PORTA,w
movwf PORTD
bcf INTCON,INTF
retfie
end
here is after clicked BUILD ALL button in MPLAB
Executing: "C:\Program Files (x86)\Microchip\MPASM Suite\MPAsmWin.exe"
/q /p16F877A "ThreeLeds.asm" /l"ThreeLeds.lst" /e"ThreeLeds.err"
/o"ThreeLeds.o"
Warning[205] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 1 : Found
directive in column 1. (list)
Error[150] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 7 : Labels must
be defined in a code or data section when making an object file
Error[150] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 9 : Labels must
Warning[205] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 11 : Found
directive in column 1. (endc)
Error[144] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 11 : Unmatched
ENDC
Warning[205] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 21 : Found
directive in column 1. (endm)
Warning[205] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 33 : Found
Warning[205] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 35 : Found
directive in column 1. (org)
Warning[203] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 37 : Found
opcode in column 1. (goto)
Warning[205] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 39 : Found
Warning[203] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 41 : Found
Warning[205] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 43 : Found
Warning[205] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 47 : Found
directive in column 1. (banksel)
Warning[203] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 49 : Found
opcode in column 1. (clrf)
Message[302] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 49 : Register
in operand not in bank 0. Ensure that bank bits are correct.
Warning[205] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 51 : Found
Warning[203] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 53 : Found
opcode in column 1. (movlw)
Warning[203] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 55 : Found
opcode in column 1. (movwf)
Message[302] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 55 : Register
Warning[203] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 57 : Found
Warning[203] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 59 : Found
Warning[205] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 61 : Found
Warning[203] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 63 : Found
opcode in column 1. (bsf)
Message[302] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 63 : Register
Warning[203] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 67 : Found
Warning[205] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 71 : Found
Warning[203] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 73 : Found
opcode in column 1. (movf)
Warning[203] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 75 : Found
Warning[203] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 77 : Found
opcode in column 1. (bcf)
Warning[203] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 79 : Found
opcode in column 1. (retfie)
Warning[205] C:\USERS\WAQAS\DESKTOP\MYPROJ\THREELEDS.ASM 81 : Found
directive in column 1. (end)
Halting build on first failure as requested.
BUILD FAILED: Mon Aug 15 22:56:46 2016
Could someone please help solving this issue
thx
Author: TK (Guest)
Hello,
you have to use a TAB for the first column and then you can place your
code.
The first column only defines LABELs/MACROs.
TK
Author: Ottmar K. (wil1)
I hope the enclosure will help you
Wil
Hi
it need not to much time to write the attached code
Wil
I still have errors .. I'm a beginner in this language . please could
someone modify it .
Author: TK (Guest)
Then you might have problems with the project settings in MPLAB.
Selected the right device?
Used ASM instead of C?
show them!
TK
Hi John
My code is not perfect, but it works well - without errors (see picture
"00_MPLAB_8.92.jpg"
Don't forget to choose in MPLAB-Menue:
"Configure"
  -> Select Device
    -> Choose in thre drop down menue "PIC16F877"
Why you don't use MPLABs build-in simulator "MPLAB SIM"? I'm sure it
will be a better option than "proteus". Personally, I don't know this
simulator "proteus". If you don't use MPLAB SIM, you will relinquishing
to a lot of benefits!
Also recommended:
  Use in MPLAB the Debugger menue "MPLAB SIM"
    -> Settings
      ->Simulator Settings "4 MHz" (fosc)
Here are few more hints:
1. Read the datasheet PIC16F877 to understand/solve the functions
   implemented in the PIC or problems caused by your code
2. You can find a template in your MPLAB folder:
   Path: "MPLAB\MPASM Suite\Template\Code\16F877TEMP.ASM"
3. Also interesting: PIC16F877.INC with a lot of labels and constants in
   context with PIC-ASM
   Path: "MPLAB\MPASM Suite\p16f877.inc"
4. SHOW THE ERRORS occured in your code (you can attach them as a file)
Wil
