Forum: µC & Digital Electronics Seek programming assistance.
Author: Jesper Mønsted (Company: n/a) (evalon1)
Hello Xilinx Forums,
I hope I post this in the right forum - otherwise please feel welcome to
move the post to the right forum.
As it is I seek programming assistance for what may likely be a simple
programming task for the person who already knows about this. I hope one
of you will be interested in working on this ... maybe also give me a
hint if such a solution already exists.
What I need is to find a solution to two somewhat different tasks yet
both are related to streaming data from a No. of ADCs into a PC at
relatively high speeds - without any drop-outs in the data stream. The
operating system preferably is Windows 7 (can be Windows 10).
The first data stream comes from 2-5 SAR ADCs (20/24 bits) and is in the
Two Complement format. This Two Complement data stream either needs to
be:
A.:   Streamed directly into the PC and stored in a .wav format.
Data transfer rates are 384 kHz, 768 kHz or 1.536 MHz and the output
from the SAR ADCs is either 20 or 24 bits, with 2-5 channels of similar
data. The file format of the data stream should be a .wav file. The
exact data read time from the SAR ADCs should be the same between data
readings (and somewhat adjustable).
B.: Or "Translated" from the Two Complement data stream to a continuous
I2S signal. Again sample rates are 384 kHz, 768 kHz or 1.536 MHz. The
SAR ADC input data formats are 20/24 bits Two Complement, and the I2S
output data format is an I2S format at 32 bits. Again, the exact data
read time from the SAR ADCs should be the same between data readings
(and somewhat adjustable), and it should be possible to transfer 2-5
channels of similar data.
I suppose the "B" solution may be the simplest but would be most
interested in hearing from you if you can make a solution for the "A"
version.
Since the precise timing of reading data from the SAR ADCs matters I
imagine that a CPLD, FPGA or similar device may be a feasible hardware
solution, however, am open to other solutions.
The second data stream comes from 2-5 1 bit ADCs all outputting data at
22.579 MHz, i.e. a 22.579 MHz 1 bit signal. I would like these data to
be entered directly into the PC and stored in a .dsf format (DSD audio
format).
I seek a programmer who already is experienced/proficient in this type
of programming and is capable of completing this job within a not
too-long period of time.
If you are interested then please post here, or contact me by PM, and we
can talk about specifics and your payment for this.
And again, if someone here knows of a solution for this that already
exists I would be most interested in hearing about it as I don't see any
reason for "re-inventing the wheel".
I hope to hear from you.
Cheers,
Jesper Mønsted
