Forum: FPGA, VHDL & Verilog User Flash Memory, Machxo2 7000HE breakout
Author: ChrisChris (Guest)
Hi everyone, I'm working with a project using a machxo2 7000HE at 50mhz,
the main code is completed with the exception of being able to have the
fpga  read and write to its internal User Flash Memory, I have figured
out how to instantiate a EFB with IPExpress but I have idea on how to
even start using it. So far its only purpose is to store a 12bit value
on button press, and  add this value to other 12 bit values across the
code where needed, its purpose is a position zero point recalibration,
as simple as it seems I just cant figure out, same went with the
hardened spi function, couldn't figure it so I made my own bit banged
version of a master spi, that was simple but time consuming. Anyone have
experience with this? I could really use some guidance please.
Author: Jan M. (mueschel)
Have you read TN1246? Besides general information, there is a section
"Wishbone framing" with some samples.
I have not seen this note, ill look through and see if it catches on,
thank you. Just be nice if there was an actual vhdl example.
  • [vhdl]VHDL code[/vhdl]
