Forum: µC & Digital Electronics ATMEL 8051 programming in C, example
von Mike M. (8051help)
I need to write only numbers (every second) in string on display (memory
mapped on 0x8001 adress) which are divding with 3 .
I must use counter not delay () for interrupt ...
I got with code below only to printing all numbers in one second.
I need 1 number per second, not all.
Anybody help?
#include <reg51.h>
#include <math.h>
typedef unsigned char byte;
byte a[8]= {7,5,16,3,1,4,11,9};
byte counter;
byte xdata display _at_ 0x8001;
byte started = 0;
int i=0;
sbit switcher=P0^0;
void Inic(void)
    EA=1;
    TMOD=1;
    TH0=0x3C;
    TL0=0xAF;
    TR0=1;
    counter=1;
void timer0(void) interrupt 1 using 2
    TH0=0x3C;
    TL0=0xAF;
30
  counter--;
31
    if(counter == 0)
32
33
            counter = 20;
34
       if(started == 1)
35
36
         if(i < 8)
37
            if(!(a[i]%3) )
38
               display=a[i];
39
         i++;
40
         if(i == 8)
41
42
            ET0 = 0;
43
            TR0 = 0;
44
            started = 0;
45
46
47
48
49
50
void main(void)
51
52
   Inic();
53
   switcher = 1;
54
   while(1)
55
56
     if(switcher == 0)
57
       if(started == 0)
58
59
          started = 1;
60
          i = 0;
61
          counter = 20;
62
63
          TH0=0x3C;
64
          TL0=0xAF;
65
          ET0=1;
66
          TR0=1;
67
68
69
