Forum: µC & Digital Electronics drv8848 ti motor controller sleep mode current draw problem
Author: MathiasH (Guest)
Hi folks,
i've a very annoying problem using a TI DRV 8848 dual H-Bridge Motor
Driver in a little project.
In the datasheet (http://www.ti.com/lit/ds/symlink/drv8848.pdf) it is
stated that it has a quiescent current as low as 3 µA.
Unfortunately if measuring current draw between GND and V_INT with my
multimeter i get around 15 mA if nSLEEP = 1 (HIGH) and around 1.5 mA if
nSLEEP = 0 (LOW).
That's arkward since setting nSLEEP to LOW should result in operating
mode and thus consuming more current, not less...
And furthermore it's still far away from 3µA current consumption stated
in the datasheet...
Why is this? Do you have any ideas?
My setup is close to the "typical application" drawing given in chapter
9.2 of the datasheet. But there is one major difference: i only use the
A in- and output, that's one H-Bridge. No sense resistor is used, AISEN
is directly connected to GND. Pins 5-7 and Pin 9-10 are left unconnected
as that's for the second H-Bridge.
AIN1, AIN2 and nSLEEP are connected to Arduino digital I/O.
AOUT1, AOUT2 are connected to a DC motor.
Capacitors between V_INT and GND and VM and GND are set as stated in the
datasheet.
VM = 12V (battery pack)
V_INT = 3.3V (Arduino)
Thank you very much for giving me any hint...
