Forum: FPGA, VHDL & Verilog VHDL complex memory array code
Author: Omar Rashad (Guest)
Hello
I am writing a simple code for a 2 dimensional complex number (integer)
array in VHDL. The matrix is basically
[ 1 1 1 1 ,
  1 -1 j -j,
  1 -1 j -j,
  1 1 -1 -1,
  1 -1 -j j]
This is my code
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity IFFT_matrix is
  port (address_r, address_c: IN std_logic_vector (1 downto 0);
        wr, wi: OUT std_logic_vector (7 downto 0));
end IFFT_matrix;
architecture behavior of IFFT_matrix is
type matrix is array (0 to 3, 0 to 3) of integer range -1 to 1; --range depends on IFFT size
constant wr_matrix: matrix:= ((1,1,1,1),(1,-1,0,0),(1,1,-1,-1),(1,-1,0,0));
constant wi_matrix: matrix:= ((0,0,0,0),(0,0,1,-1),(0,0,0,0),(0,0,-1,1));
begin
wr <= std_logic_vector(to_signed(wr_matrix (to_integer(unsigned(address_r), to_integer(unsigned(address_c)))));
wi <= std_logic_vector(to_signed(wi_matrix (to_integer(unsigned(address_r), to_integer(unsigned(address_c)))));
end behavior;
Compiling with vhdlan gives me this error:
"Parsing design file 'IFFT_matrix.vhd'
Error-[IEEEVHDLSYNTAXERR] Syntax error
IFFT_matrix.vhd, 18
  ...x (to_integer(unsigned(address_r),
to_integer(unsigned(address_c)))));...
  Syntax error detected during VHDL parsing.
IFFT_matrix.vhd, 19
"IFFT_matrix.vhd": errors: 2; warnings: 0.
[oalsamma@bifur ~/intel]$ gedit IFFT_matrix.vhd"
I cannot quite figure out what to fix. Can you help please?
Author: FemtoMaik (Guest)
check your brackets or use an editor which does this for you :-)
wr <=
  std_logic_vector(
    to_signed(
      wr_matrix(
        to_integer(unsigned(address_r)),
      wr'length
  • [vhdl]VHDL code[/vhdl]
