Forum: FPGA, VHDL & Verilog FPGA: i get a different answer in modelsim and in device
Author: Amine Amine (aminemr)
I'm new to VHDL and require some help. I'm Interfacing with Artix 7 to
make a simple modular multiplier but i have some problems. When I
synthesize my code i get some warnings which i think are wrong so i
ignored them. when I run post route simulation i got the results as
required but when i burned the code on hardware i get a different answer
for the same value that i check in the stimulus.
Can some one please help me.
the warnings that i get are:
Xst:737 - Found 1-bit latch for signal <zt<1>>. Latches may be generated
from incomplete case or if statements. We do not recommend the use of
latches in FPGA/CPLD designs, as they may lead to timing problems.
Xst:1710 - FF/Latch <C_b_out_30> (without init value) has a constant
value of 0 in block <Montgomery_multiplier>. This FF/Latch will be
trimmed during the optimization process.
Xst:1895 - Due to other FF/Latch trimming, FF/Latch <z8_19> (without
init value) has a constant value of 0 in block <Montgomery_multiplier>.
This FF/Latch will be trimmed during the optimization process.
Xst:3001 - This design contains one or more registers or latches with an
active
asynchronous set and asynchronous reset. While this circuit can be
built,
it creates a sub-optimal implementation in terms of area, power and
performance. For a more optimal implementation Xilinx highly recommends
one of the following:
1) Remove either the set or reset from all registers and latches if
not needed for required functionality
2) Modify the code in order to produce a synchronous set
and/or reset (both is preferred)
3) Use the -async_to_sync option to transform the asynchronous
set/reset to synchronous operation
(timing simulation highly recommended when using this option)
Author: guest (Guest)
There is a very simple design rule concerning latches:
Do not use latches.
The problems you are seeing are very likely a direct result of having
latches. Correct your design until you have no latch warnings.
  • [vhdl]VHDL code[/vhdl]
