Forum: FPGA, VHDL & Verilog One bit for status
Author: Raju (Guest)
Hi All,
I have 4 registers (for Address, Data_to_be_read, Data_to_be_written &
Control) in a serial RX block.
This will be accessed by another Serial Tx Master device, it accesses
the address register, if control is read=1, goes to that address and
read the data from that address and copies it to Data_to_be_read
register.
If the control is write=1, it reads the address from Address register,
copies data from Data_to_be_written register and writes it on to the
address location.
Now my problem is if i use 1 bit for control register '1' for read and
'0' for write, it may start reading at correct times, but keeps on
writing all the time when the bit is '0' . (end of reading not
necessarily mean writing)
(however if i use two separate 1 bit lines for read and write, i can use
pulse in those leans to decode when to start reading and when to start
writing).
Is it possible to use 1 bit for control and still start the reading
operation and writing operation.
Thank you,
See it that way: you can read every address randomly at every time.
But you only should write stable data to a valid address. So the
default of that flag must be: Read.
One problem may occur, when you try to read registers that implicitly
write something. For example when you read a interrupt register, and
that read itself resets the interrupt request (as it is in some uC).
  • [vhdl]VHDL code[/vhdl]
