Forum: FPGA, VHDL & Verilog Basic memory unit help
Author: Omar Rashad (Guest)
I get the following error when comiling:
The symbol to_int does not have a visible declaration.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity Mem is
generic (N: integer; -- N bits wide (# of columns)
         K: integer); -- K bits long (# of rows)
port (Din: IN std_logic_vector (N-1 downto 0);
      clk,rw_en: IN std_logic;
      add_in: IN std_logic_vector (K-1 downto 0);
      Dout: OUT std_logic_vector (N-1 downto 0));
end Mem;
architecture behavior of Mem is
type mem_array is array (2**K-1 downto 0) of std_logic_vector (N-1 downto 0);
signal our_array: mem_array := (others =>(others => '0'));
begin
process (clk, Din, rw_en, add_in)
--variable address: integer;
begin
  if (clk = '1' and clk'event) then
    if (rw_en = '1') then
      our_array (to_int(unsigned(add_in))) <= Din;
    else
      Dout <= our_array (to_int(unsigned(add_in)));
    end if;
  end if;
end process;
end behavior;
The function is called "to_integer()"...
Try this with Google translator, its German:
http://www.lothar-miller.de/s9y/categories/16-Numeric_Std
: Edited by Moderator
Thank you. My bad....
  • [vhdl]VHDL code[/vhdl]
