Forum: ARM programming with GCC/GNU tools unrecognised emulation mode: cpu=cortex-m3
von Ruslan S. (Company: geomashsnab) (mudila)
I have attached the makefile that I use to compile compile my first
simple code (main.c) for the stm32VL board. My operating system is OS X
Maverics and I use Yagarto with STLINK. I attached the bash_profile file
to show how the Yagarto toolchain is set. The main.c file gets operated
first by the local Makefile (attached) which calls the Makefile.common.
When I run the make command I get the following error. Any ideas how I
can fix this?
Demo Ruslan$ make
/Users/Ruslan/yagarto/yagarto-4.7.2/bin/arm-none-eabi-ld
-T/Users/Ruslan/STM32-Template/stm32f100.ld -mthumb -mcpu=cortex-m3  -o
Demo.elf startup_stm32f10x.o system_stm32f10x.o  main.o
/Users/Ruslan/yagarto/yagarto-4.7.2/bin/arm-none-eabi-ld: unrecognised
Supported emulations: armelf
make: *** [Demo.elf] Error 1
von gjlayde (Guest)
In general it's not a good idea to call ld directly for linking.  Use
gcc as linker driver and it will feed ld with the correct options and
paths.
von Rolf Magnus (Guest)
And -m has a completely different meaning in ld.
Thank you everyone for the responses. I got it to work under yagarto and
gcc! The problem was that I was calling for ld directly instead of
allowing gcc to take care of it.
i am working now on debugging the code in gdb. Is it possible to ask gdb
to print the value of i every timy the i is updated? As of now i use the
manual print i command in gdb but it is no practical I think.
