Forum: ARM programming with GCC/GNU tools STM32 GDB on Mac OS
Author: Ruslan Si (Company: geomashsnab) (mudila)
I am just installed the STLink and Yagarto on my Mac OS 10.9.5 and it
took me 3 days:( .
I am experiencing the following GDB problem after stlink connects to my
STM32VL Discovery board.
I started the instance of STLINK by using command :
./st-util --stlinkv1
and after that I opened another terminal to run the GDB:
tcms-MacBook-Pro:yagarto-4.7.2 Ruslan$ arm-none-eabi-gdb
/Users/Ruslans/STM32-Template/BlinkingLight.elf
but when I try to load the .elf by by using command
(gdb) target extended-remote :4242
I get this error:
Remote debugging using :4242
0x08000b4c in GPIO_Write (GPIOx=0xa, PortVal=<optimized out>)
    at
/l/arm/STM32F10x_StdPeriph_Lib_V3.5.0/Libraries/STM32F10x_StdPeriph_Driv
er/src/stm32f10x_gpio.c:423
423
er/src/stm32f10x_gpio.c:  No such file or directory.
I am very new to unix based systems or to GDB and GCC so I have problem
with fixing this issue. Could someone advice on how to address this
problem? I started by loading the STM32VL library into my project folder
STM32 Template but the error persists. I don't understand why gdb is
looking for thestm32f10x_gpio.c since the .elf file is already a
compiled and ready to be loaded object.  Please help.
Author: Lyon (Guest)
Download the follwings:
a)
http://www.eclipse.org/downloads/packages/eclipse-...
- this is the Eclipse IDE
b) https://launchpad.net/gcc-arm-embedded - this is the latest version
of bare-metal GNU tools for ARM/Cortex-Mx micros
c) http://gnuarmeclipse.livius.net/blog/plugins-install/ - this is to
allow managed make projects (you do not need to write makefiles, are
written automatically by the plug-in) and also allow visual debugger
d) openocd, as described here:
http://gnuarmeclipse.livius.net/blog/openocd-install/ - tools to connect
to your board
L
