Forum: ARM programming with GCC/GNU tools Thumb mode error
von Pavel Y. (Company: EPFL) (pavel_47)
Hello
Trying to build project I get the messages like this: (also please see
the picture):
=== Build: Debug in udp_multicast (compiler: GNU GCC Compiler for ARM)
C:\Users\Pavel\AppData\Local\Temp\ccs3i4N5.s|575|Error: selected
processor does not support Thumb mode `it lt'
C:\Users\Pavel\AppData\Local\Temp\ccs3i4N5.s|576|Error: Thumb does not
support conditional execution
C:\Users\Pavel\AppData\Local\Temp\ccs3i4N5.s|583|Error: unshifted
register required -- `orr r2,r2,#196608'|
=== Build failed: 3 error(s), 0 warning(s) (0 minute(s), 0 second(s))
Thanks for any suggestion.
BR
Pavel
von hellhammer (Guest)
Can you show the code where the error occurs?
Which processor do you use?
Hello Hellhammer
The problem is that compiler doesn't point to the source. According to
the error messages, the "guilty" is a some file ccs3i4N5.s (that doesn't
exist when I try to find it in the specified location).
The target processor is CC2538: ARM Cortex™ M3 With Code Prefetch.
I'm not sure that it's properly specified: the source code I get from
3rd party company, which doesn't provide support.
Is it important to specify exact type of CPU.
Before I worked with another project (but with the same CPU) and it was
OK.
BR
Pavel
