Forum: ARM programming with GCC/GNU tools STM32F051 I2C slave problem
Author: klaus (Guest)
I have in a STM32F051k project a problem with the I2C as Slave.
I send from an AVR:
Start/address Wr/command/repStart/address RD/ ... read information /
Stop)
The read information is command/count/data.
Exact once everything is ok but then I come
Seldom times to the point for sending the count, but never again to
sending the data.
Most comments are in German, sorry.
#define OUT_STATE_NC       0
#define OUT_STATE_CMD      1
#define OUT_STATE_LENGTH   2
#define OUT_STATE_DATA     3
unsigned char Info[128];
unsigned char State[64];
__IO unsigned char InputCounter;
__IO unsigned char OutputCounter;
__IO unsigned char Output_State;
__IO unsigned char Data_Out_Max;
__IO unsigned char data_in[MAXBYTES+1];
unsigned char *pData_Out;   /* Pointer auf die Ausgabe Daten */
unsigned char Data_Cmd;
TBOOL bRecStart;
volatile TBOOL new_data; /* 1 = neue daten */
__IO uint16_t IIC_Direction;
void I2C1_IRQHandler(void)
   if (I2C_GetITStatus(I2C1,I2C_IT_ADDR)) //  meine Adresse erkannt?
      I2C_ClearITPendingBit (I2C1,I2C_IT_ADDR);
      // Start
      IIC_Direction = I2C_GetTransferDirection(I2C1);
      if (IIC_Direction == I2C_Direction_Transmitter) // IIC Write ?   AVR -> ARM
         InputCounter = 0;
         OutputCounter = 0;
         Data_Out_Max = 0;
         Output_State = OUT_STATE_NC;
         bRecStart = TRUE; /* setze flag; System ist am empfangen */
      else // IIC Read ARM -> AVR
         if (InputCounter == 1) /* nur die Register Adresse vorher empfangen?*/
            Output_State = OUT_STATE_CMD;
            Data_Cmd = data_in[0];
            switch (data_in[0])
            case B_GET_INFO:
               pData_Out = (unsigned char *)&Info;
               Data_Out_Max = sizeof (Info);
               break;
            case B_GET_STATUS:
               pData_Out = (unsigned char *)&State;
               Data_Out_Max = sizeof (State);
               break;
            default :
               Data_Out_Max = 0;
               break;
         else
         OutputCounter = 0;
         InputCounter = 0;
   else if (I2C_GetITStatus(I2C1,I2C_IT_STOPF)) // Stopp erkannt?
      I2C_ClearITPendingBit (I2C1,I2C_IT_STOPF);
      // Stop
      Data_Out_Max = 0;
      OutputCounter = 0;
      if (bRecStart != FALSE)
         if (InputCounter == MAXBYTES) /*   alle daten empfangen ?*/
            new_data = TRUE;
      } /* else ->> komme aus nicht def. zustand */
      bRecStart = FALSE; /* loesche flag, Daten Empfang laeuft */
   else  if (I2C_GetITStatus(I2C1,I2C_IT_RXNE)) //  was empfangen?
      uint8_t In_Datum;
      In_Datum = I2C_ReceiveData(I2C1);
      if (InputCounter >= MAXBYTES) /* zu viele Daten empfangen ? */
      else /* Kann noch Daten empfangen ! */
         if (bRecStart == TRUE) /* laeuft Daten Empfang ? */
            data_in[InputCounter] = In_Datum; // das sind die Daten -> also speichern
            InputCounter++;
      Data_Out_Max = 0;
      //I2C_ClearITPendingBit (I2C1,I2C_IT_RXNE); // macht das auslesen schon
   else   if (I2C_GetITStatus(I2C1,I2C_IT_TXIS)) //  gesendet ?
      I2C_ClearITPendingBit (I2C1,I2C_IT_TXIS);
      switch(Output_State)
      case OUT_STATE_CMD:
         I2C_SendData(I2C1, Data_Cmd);    // 1. Byte ist der Befehl zu dem die Daten passen
         Output_State = OUT_STATE_LENGTH;
         break;
      case OUT_STATE_LENGTH:
         I2C_SendData(I2C1, Data_Out_Max); // 2. Byte ist die Laenge
         Output_State = OUT_STATE_DATA;
         break;
      case OUT_STATE_DATA:
         if (OutputCounter < Data_Out_Max)  // Kann ich noch Daten senden?
            I2C_SendData(I2C1, (*pData_Out));
            pData_Out++;
            OutputCounter++;
            if (OutputCounter >= Data_Out_Max)  // Kann ich noch Daten senden?
         else
            I2C_SendData(I2C1, 0); // sende NULL -> es wird zu viel abgefragt!
         break;
      case OUT_STATE_NC:
      default:
          I2C_SendData(I2C1, 0); // sende NULL -> es wird mist abgefragt!
         break;
    else  if (I2C_GetITStatus(I2C1,I2C_IT_NACKF)) //  erkannt?
      I2C_ClearITPendingBit (I2C1,I2C_IT_NACKF);
   else   if (  (I2C_GetITStatus(I2C1,I2C_IT_BERR)) //  Fehler erkannt?
      || (I2C_GetITStatus(I2C1,I2C_IT_ARLO)) //  Fehler erkannt?
      // Sollte nicht passieren
      InputCounter = 0;
      OutputCounter = 0;
      Data_Out_Max = 0;
      I2C_ClearITPendingBit (I2C1,I2C_IT_BERR);
      I2C_ClearITPendingBit (I2C1,I2C_IT_ARLO);
void Twi_Init(void)
   I2C_InitTypeDef  I2C_InitStructure;
   NVIC_InitTypeDef NVIC_InitStructure;
   GPIO_InitTypeDef  GPIO_InitStructure;
   InputCounter = 0x00;
   Data_Cmd = B_GET_NC;
   bRecStart = FALSE; /* loesche flag, daten empfang laeuft */
   // Ausgabe blockieren
   Data_Out_Max = 0;
   OutputCounter = 0;
   I2C_DeInit(I2C1);
  /*!< I2C Periph clock enable */
   RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
   /*!<  GPIO clock enable */
   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
   RCC_I2CCLKConfig(RCC_I2C1CLK_SYSCLK);
   GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_1);
   GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_1);
     /* Configure I2C pins:  SDA & SCL  ----------------------------*/
   GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;
   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
   GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
   GPIO_Init(GPIOB, &GPIO_InitStructure);
   /*!< I2C Init */
   I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
   I2C_InitStructure.I2C_Timing = 100000;
   I2C_InitStructure.I2C_DigitalFilter = 0;
   I2C_InitStructure.I2C_AnalogFilter = I2C_AnalogFilter_Enable;
   I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
   I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
   I2C_InitStructure.I2C_OwnAddress1 = MYADDR;
   I2C_Init(I2C1, &I2C_InitStructure);
   /* Enable I2C event interrupt */
   I2C_ITConfig(I2C1, (I2C_IT_ERRI | I2C_IT_STOPI | I2C_IT_ADDRI | I2C_IT_RXI  | I2C_IT_TXI), ENABLE); // I2C_IT_NACKI
  /* Configure the I2C event priority */
   NVIC_InitStructure.NVIC_IRQChannel = I2C1_IRQn;
   NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
   NVIC_Init(&NVIC_InitStructure);
  I2C_Cmd(I2C1, ENABLE);/* I2C ENABLE */
Regards,
Klaus
Is there really nobody who can help me?
OK I found that the first communication is activating 2 times the TX int
after the address + Wr and than just once.
Maybe this information can help to solve my problem.
Just add a I2C_SoftwareResetCmd(I2C1); at the end of the stop part and
it is working.
A I2C_ClearFlag(I2C1, I2C_FLAG_TXE); at the beginnig of the address
match didn't work.
klaus
