Forum: Analog Circuits Antenna Selection for 868 MHz transceiver
Author: HF (Guest)
Dear All,
I have difficulty at choosing the optimal quasi-omni-directional antenna
[compact & cheap, but good-performance at urban area: 3-5 km @ +20dBm,
lowest data rate, LoRa, -148dBm rec. sensitivity] for RFM95 868 MHz
transceiver module.
What do you think about these two PCB trace antennas?
http://www.ti.com/lit/an/swra227e/swra227e.pdf
http://www.ti.com/lit/an/swra416/swra416.pdf
As far as I have read & understand, (although the helical one needs
accurate matching) they both have better gain parameters than these
comparatively more expensive solutions:
https://www.linxtechnologies.com/resources/data-gu...
http://www.mouser.com/catalog/specsheets/ANT-868-u...
Another option, I may use simple wire. (What kind of wire should use?)
But I have to bend it twice to make it fit to a 4x4cm case. Does it
degrade the performance heavily?
Thank you very much for sharing your knowledge & experience.
Best regards...
Author: HF (Guest)
Why is not there any "HF, Funk & Felder" sub-forum for the English
version?
