Forum: DSP MATLAB SHARC BTC failure
Author: Markus (Guest)
hi guys,
i am working on a student bachelor thesis where i should implement a BTC
from matlab to the SHARC ADSP-21369 EZ-Kit to edit parameters for a
simple 3-band-EQ during the board's runtime.
i have now a class in matlab including the methods for accessing,
writing and reading the BTC and i have initialized the channels in
VisualDSP++ like shown in the getting started example.
now i have the following problem:
i will transmit filter coefficients für a biquad filter, so the
numerator-coefficients are 3x1 cell array, the denominator-coeffs 2x1
cell array
if i try to send these values through the BTC, the BTC memory window
shows me, that only one single coefficient of the array is edited, the
others get 0. a very interesting point is, that in the 3x1 cell array
the 2nd coefficient is edited, the first and the third get zero.
has anyone an idea how to fix this? i would need quite a quick solution,
because i have to presentate my project on monday.
here is the code ob my accessBTC.m
classdef accessBTC < handle
properties
    numChannels = [];
    isInitialized = 0; %Logical 0 or 1 to indicate if the class is instantiated to connect to the VisualDSP session
end
properties(SetAccess = private)
    channelList = {}; % Array of channel objects
end
methods
    function initialize(obj)
        a = actxserver('VisualDSP.ADspApplication');
        btcPlugin      = a.PluginList.invoke('Item','BtcManager');
        btcManager     = btcPlugin.Open;
        btcChannelList = btcManager.ChannelList(int16(0));       % Get the channel list in processor #0 (always INT16)
        obj.numChannels = btcChannelList.Count;
        disp(['Total Number of Channels: ', num2str(obj.numChannels)]);
        % Create the BTC Channel interfaces
        for i = 1: obj.numChannels
            obj.channelList{i} = btcChannelList.invoke('Item',int32(i-1));
        end
        obj.isInitialized = 1;
       % S=saveobj(obj);
   end % End of Method: INITIALIZE
    function outVal = read(obj,channelNum,width)
        % Default width is 32; other possible values: 16, 8
        % Channel num starts frm 0
        if nargin ==2
            width = 32;
        end
        widthStr = ['btcWidth',num2str(width)];
        btcChan = obj.channelList{channelNum};
        out_val = btcChan.Read(widthStr);
        outVal = cell2mat(out_val);
    end % End of Method: READ
    function write(obj, channelNum, val)
        % input val needs to be a scalar or a vector of int32 or in16 or
        % int8 values
        if nargin ~=3
            error('WRITE method for accessBTC object needs 2 inputs.')
        end
        btcChan = obj.channelList{channelNum+1};
        btcChan.Write('btcWidth32',num2cell(val));
    end %End of Method: WRITE
    function reset(obj)
        obj.numChannels = [];
        obj.isInitialized = 0;
        obj.channelList = [];
    end %End of Method: RESET
end
so if i sending for example these single arrays
    num_1 = [1.324; -1.45; 0.83]
    den_1 = [-1.45; 0.74]
i am getting in my BTC memory window as floating point
    num_1 = [0.0000000; -1.45; 0.0000000]
    den_1 = [-1.45; 0.0000000]
has anybody an idea how to fix this?
thanks a lot and best regards,
markus
